E320 cdi V6 cylinder numbering
machbuffet
Northern Ireland
E320cdi / 2006 / 3.0 V6
Hi guys
Could anyone confirm the correct numbering sequence of the 320 cdi V6 engine cylinders.
I think it's (looking from front) drivers side 1,2,3 front to back and passenger side 4,5,6 front to back.
I'm comparing the injector numbers to the ecu programming and just need to be sure.
Corned
East Midlands
2005 S211 E320CDI Avantgarde
I think you're barking up the wrong tree with this (if I have understood your previous thread correctly).
If the injectors were out of sequence, the problems you are having would be persistent, not just on part application of the throttle.
If the ECU program was firing the injectors in the wrong pattern, resulting in lumpy running, this would be throughout the rev range. The ECU will not be re-numbering the injectors part way through a running cycle!
