E350 engine change
Rich MP
E350
Hi I’ve changed the engine on my friends e350.
om642
ive got a fault coming up with cam sensor hall b6/1
I’ve check the wires and scoped the sensor and all is looking ok. But the car struggles to start and goes into limp mode.
I’m wounded does anyone know if I would need the ecu of the replacement engine.
would the camshaft signal vary from engine to engine?????
bembo449
gainsborough , lincolnshire
I would argue the if you haven't used the original injectors off the old engine that may be the issue , if you used a bare engine then if could be just fuel pressure needs a bit of a nudge , ive had it plenty often before where ive swapped an engine and had to tow start it to get everything going properly
R
Rich MP
E350
It starts and runs just cranks a few more times than you would like before it finally starts. And just has this camshaft fault every time you start stored in the trouble codes
R
Rich MP
E350
you never said which set of injectors or how much of the old unit you used pal ??
mused everything from the old engine to the new. Including the loom
bembo449
so it could be a timing issue then , assuming the old car started on the button ? id still look at the fuel side of things , pressures etc
R
Rich MP
E350
So possible timing issue such as the chain stretched/moved?
and check fuel pressures are the next steps.
bembo449
definitely pal , if the cam sensor is defo ok its the next logical thing that would effect starting unless fuelling isn't quite right but the fact you have swapped the bare engine suggests mechanical to me and hence why I think you shouldnt rule out a timing issue
R
Rich MP
E350
So shall I go for a full timing check or is there a way of check tensioner length ?
bembo449
you have a scan tool so I would think someone on here will be able to tell you what values you should see pal ?
stumo
VIC, Australia
ML270CDI x3 2002,03,04 | Sprinter 316CDI 2003 LWB
What about the crank sensor and teeth? Were they off the original engine and/or were they damaged. If the crank sensor is skipping teeth at cranking speeds it can sometimes show up as a cam sensor failure.
R
Rich MP
E350
  • #17
The flywheel was different on the new engine so I’m sure we used the old one.
R
Rich MP
E350
  • #19
I get the feeling this is going to be something daft in the end pal
im worried that the camshaft have a different dephaser. I’ve rang merc parts and they saying the camshafts are different from the engine codes I gave them.
make me think it’s possible ecu coding problem.
