ESP fault a210
texaspete
Hi
I'm new to this forum so please bear with me.
I have an 02 A210, the other day the abs/ESP light came on and it went into limp mode.
I took it to my local garage who told me to go to my local mercedes garage. They plugged it in and said I need a new ESP control unit which they could supply and install for £1250!!!!
Since then it drives fine but the warning light that looks like an engine stays on but the abs/ESP light doesn't? Is this right?
I have managed to source a new control unit for £150, can I just unplug the old and plug in the new?
Please help :)
The price for that control unit is about correct, i have fitted 2 in the last year, i use a company in Poole which i found to be the cheapest at £250, so please share your supplier please,
Once you have a new unit, it then has to be coded using star!!
Its not plug and play, a driving cycle after coding is needed to teach the unit its parameters!!
Welcome to the forums!!!
I wonder is this is worth soldering up,,and it is listed as getting bad connections where it plugs in,,would it be worth spraying with a good nondrying switch cleaner
Talking of soldering Malc, while your in the "zone" on thursday, we have a A class engine control module and a cluster of a 209 which is totally dead if you feel brave???
I will do the 170 on the spot,, the others I would have to bring back owing to the amount of dismantling
The engine ECU is off our other A class, the cluster is off a customers car, dont know how long we can have it, Many thanks anyway, lunch on us then thursday!!!!!
T
texaspete
Hi, thanks, what should I expect to pay for the star coding? The comany I found is www.dronsfields.com. Is the engine looking light normal?
I will know on the Friday /Sat if anything can be done with the other two units
