Fell into engine
  • Moderator
  • #101
A bent rod is a weakened rod and can fail at a later date due to forces not being worked in a straight line
Meh, if the engine has to come apart I'll wait until it blow the rod through the block. I'm sure it will be fine though.
I once bent the con rod on a 300td, only noticeable by a bit more diesel knock at idle. That did 30,000 before it was sold on.
star
Reading
Smart + others :)
I’m sure it’ll be ok.
Whilst possible it's not overly likely to have bent a rod.
I'm sure it'll be fine.
  • Moderator
  • #104
I will let everyone know, as always.
Big screw in my tyre today on the m25 queue "tyre defect, check tyres" on dash, so at least my luck is consistent.
  • Moderator
  • #105
STILL waiting on my unobtainable fuel injectors. Wont arrive before easter holiday now.....
Botus
S500/2010/500
bummer
find some other project to work on, at least with the awful weather expected, you don't need to stress over a lack of traction
  • Moderator
  • #107
bummer
Time to pull the head off the diesel bike just to replace the thermostat housing (thanks kubota), I can put up a gazebo for that one.
I still have the 63 :p
  • Moderator
  • #108
Injectors fitted (arrived saturday). Some very odd behaviour. Think I have cracked it. Update to follow
  • Moderator
  • #109
So injectors fitted. First turn of the key, car ran like absolute CRAP, misfiring on 1 2 7 8
Reset adaptions, started up again, once again running like crap.
Opened the oil filler and blown away with the smell of petrol. Sump must have had a litre or so of petrol in it, so much petrol in fact that it was causing misfires.
Changed oil/filter and running smoothly again. Apparently no bent conrods so happy days there.
Misfire still there however so off to MSL as I have reached the limit of my expertise.
silestanix
London!
03' BMW 325Ci
Just read through this whole thread, jesus Alex...!
Botus
S500/2010/500
I still think I have a point, the have just bodged up some map on the back of a fag packet - tuning to death so much, they have the injector timing overlapping, its trying to open before the last signal to close has been completed
bigger injectors (flowing more fuel), a supplementary injector or less ambition, sounds like the right course of action
  • Moderator
  • #112
Injector duty cycle doesn't go past 85% on this map, but try telling them there's a problem with the map or that it needs tweaking. It gets you nowhere and is very frustrating.
In addition this engine/platform has been tuned quite a bit by EC so its had a fair amount of testing.
www.W140.co.uk&www.r129.co
