Gear box oil Capacity as of 08-08-05
722.329/341/342/343/344/351/352/357/359/361/363/367/368/369/371.
From initial fill 7.3 litres..... for fluid change 6.2 litres.
Shell Donax TA D-21666,21774.....Castrol TQD 22256.......BP Autran MBX
_________________________________________________________________
722.350/353/354/355/356/358/362/364/365/366/370.
From initial fill 8.6 litres.... for fluid change 7.7 litres.
772.500/501/502/503/504/505/506/507/508/509/510.
for new box 7.3 litres for oil change 6.2 litres.
Oil type
722.600/601/604/605/606/607/608/609/611/614/616/617/618/629/634/639/660/661/662/664/665/666//661/662/664/665/689/695/699/996.
for new box 7.5 litres (+0.5)
MB 236.10 ATF A001 989 2303...MB 236.10 001 989 2103..........
Shell ATF 3403-M 115
772.372/380/382/384/385/394/396/397/398/399.
new box 7.3 litres. Change 6.2 litres. Fluid type
772.331 8.6 from new. Fluid type
772.400/403/411/414/420/421/423/424/425/426/427/428/431/434/441/443.
From new 6.6 litres Change 5.5 litres. Fluid type
Shell Donax TA D-21666,21774.....Castrol TQD 22256....BP Autran MBX
772.408/409/412/413/415/417/418/433/435/437/438/440.
from new 7.1 litres.... Change 6.0 litres. Luid Type
772.800/810...................................................
When refilling 5.7 litres....................................
When refilling and converter 6.0 litres................
When refilling converter and cooling 6.5 litres.....
For fluid change without converter 4 litres.......
For fluid change with draining the converter 6.0 litres.
Fluid type CVT transmission oil type ATF 28-CVT, A001 989 46 03
All of the above transmision fluids are recomended by MB, This is for the UK,there are other fluids for different countries.
Malcolm
  • #2
Blobcat please make it sticky,cant do it again.
malcolm
Pipemaster
East Midlands
SL350 R230 / 2006 / 3500
Bravo
Excellent thanks Malcolm just what i needed to chnage the oil in my sealed for life unit next week!!
benz girl
Banned
uk
My dad changed the oil in his box at the weekend,,,how do you check the oil level,,,is it when it is running or when it is cold,,,HELP>the car is a w202 sport.year 2000.
eric242340
Banned
China
Engine running and at normal working temperature. Run the shift lever through the gears and back to park. Engine still running, remove the dipstick and ensure the level is between low and high marks. Too much oil or too little oil is not good.
BigJohn
North West
Please Please Malcom
Just a little more
Can you add the information for the the 722.7XX ranges for the W168 A Class and W141 - Vaneo
Thank you
Just a little more
Thank you
I will see what I can do, If I have it,you can too. :D :D
nim
glasgow
Hi great information but I cant find my gear box (E240 V6 2.6 W210 ) box code 722.696 there is similar which is 7.5 +0.5 I would assume this is my box
haydar
Lahore, Pakistan
Oil type
Malcolm
Malcolm, why is the 722.6 box different in that it doesn't have a 'for oil change figure'? What does the (+0.5) mean?
Cheers
Cheers
I have been waiting for some one to ask that question, but I do not have the answer. It is possible that someone like Type 49 knows
Is it because of the lack of torque converter drain plug?
Not really so as the plug was dropped 1999 and the box has been out since 1997
I just do not know why this info was missing from the list on the 772.6
Yours sir is a 722.6 box without the drain plug
C240yaz
West Scotland, not far from Mull of Kintyre
Television, please clarify the (+0.5). Is this for pipe line Qty ?
  • #18
I do not have any more info on this, it could be that some boxes need a bit more, I will try and find out
  • #20
Thank you Mr Black for pointing that out :D
