Gear shifts out of park when the brake pedal not depressed.
EmilysDad
Bury Lancs
ML350
I always depress the clutch pedal when starting a manual car - it takes the gearbox loading off the starter.
but also pushes the crankshaft forwards onto the thrust brg .... :rolleyes: and I'm not really sure how a gearbox can load a starter/engine
davidsl500
Operating the clutch means the first motion shaft is disconnected from the engine - the clutch driven plate doesn't spin ( saves a bit of load) and no gears are turning in the gearbox in the hydraulic oil so no drag /load on the starter from that either.
Try it in winter with a bad battery, it can be the difference between starting and not starting....
Ditto but more to prevent me inadvertently starting it in gear if I haven't put it in neutral properly.
www.W140.co.uk&www.r129.co
