Gearbox Safe Mode & ABS light on
Bruce Mansell
I have a W202 1997 C230 K 5 speed electronic auto box. I have not used the car for 4 weeks and now it sticks in limp (safe) mode and the abs light is on. Could it be low voltage in battery? car starts normally on key.
Also how do i reset the box using the throttle & ignition as I have lost the instructions.
Bruce
I would give the car a run the best that you can,,do check that the battery is giving over 12 volts, then try again
Alex Crow
Super Suffolk
was it jump started? have you checked the fuses.
B
Bruce Mansell
w202 gearbox problem & ABS light on
No It was not jump started I have not checked any fuses. Can you tell me what to check and where to find them.
Do you know how to reset the box from safe mode?
Tel: 020 8863 9233
