Guys.. what is that? (M111.960)
P
Peter Kevin
Indonesia
1996 W124 E220
  • #21
Do you ever get a need to use the internal heater given the weather where the car is?
I never had the urge to turn on the heater because here in Indonesia the weather outside is usually around 30ish C on daylight so AC is always necessary.
P
Peter Kevin
Indonesia
1996 W124 E220
  • #22
I still cant get that rubber thing off the pipe it sticks there really good it just wont come off. I tried gouging it but its elastic material just make it impossible it just sticks right back to its place... I really need help:D
Jim2
What ever it is, it's not natural. If it's a "Rubbery" substance, see if you can screw a wood work drill bit into it by hand, and keep a vacuum cleaner going beside it while you are at it. That should get it out.
star
Reading
Smart + others :)
It maybe that the heater is stuck on hot, so a previous owner blocked it given where you live. If you never need heat, leave alone.
00slk
Cambridgeshire UK
What do u mean?
On most cars the heater unit is situated inside and up behind the dash board, if the heater matrix leaks it drips water in side the heater casing and eventually fills and over flows onto the carpet, hence wet carpet ;)
P
Peter Kevin
Indonesia
1996 W124 E220
  • #30
Since most people here telling me to leave it alone.. I guess Im just gonna leave it alone.. but is it not going to damage my engine in the long run?
P
Peter Kevin
Indonesia
1996 W124 E220
  • #31
Thanks, will definetely try it. I like my machine clean and originale:D
Before you do that run some water into the rubber hose it attaches to. See if water come out the radiator (with the cap off). Also check you don't get wet carpets.
P
Peter Kevin
Indonesia
1996 W124 E220
  • #33
Guys, I got another problem.. the car was running completely fine literally minutes ago, I took it for drive after completing my coolant flush, went to refuel, and it suddenly hesitate and began to sound like an old V8.. :D
its shaking like crazy and act like the engine is about to die, I popped the hood, I see nothing unusual besides the machine is shaking like theres no tomorrow and went to the back and see white smoke, not too thick, but a lot.
And now Im at the side of the street, raining, and clueless.. is this somethig I can fix or I should just tow this thing somewhere
Heres the video
mattkh
England
A160 W168 1999 1.6
Sorry to hear that.
Did the shaking start after you put some fuel in it.?
On your test drive, were you keeping an eye on the temperature needle?
To be on the safe side, it is advisable to get it towed to wherever you want.
P
Peter Kevin
Indonesia
1996 W124 E220
  • #35
Sorry to hear that.
No, it actually started before I got to the gas station, but maybe it was my fuel, because it is running very low
That looks like lot of water in the oil.
Pop outcall the spark plugs and compare them. You should find one that's considerably cleaner than the rest.
P
Peter Kevin
Indonesia
1996 W124 E220
  • #38
Yeah the water in the reservoir all empty I guess it all went into the oil:(
could it not be then that the thing blocking the cooling pipe is something like radweld and the fact you just flushed the coolant and found this problem means you dislodged some of that radweld.
mattkh
England
A160 W168 1999 1.6
Sometimes after a coolant flush you can get air locks in the pipes. After running the engine the water level goes down as the air gets out.
