Have you had a problem that has been fixed by a forum post?
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
Needed a xenon bulb , M B quoted me £ 110 plus vat ,
A well know chap on this forum pointed me in the direction of a PAIR of correct bulbs for little over £ 50 delivered .
So that alone makes it well worth being a member .
Had many good results on here .
Thanks guys.
MALTESESL500AMG
MALTA
2004 SL500 AMG KIT
Im new here and had some good advise from the member television.. he even took time to check out with Mercedes supplied diagrams in order to give the right answer to one of my questions.. worth being an active member... by the way I posted the fault found to my problem on the thread..just for others to see...
Craiglxviii
Cambs UK
Malcolm (Television) actually hand-draws each and every workshop diagram whenever required.
rodisi
Germany
E220CDI 1999 W210
The forum has provided me with a lot of information and has saved me time, money and frustration. Television and Naraic come to mind as having helped but I'm sure many others also have - if only this old brain would remember.
Wrong thread!
Kirbs
Sutton Coldfield
ECLASS 280 sport,2009,3.0 and SL350 2004
I am good at presenting cars but rubbish at everything else,so just a quick count I have asked for help on my 2 cars 19 times in the past 12 months and if not directly resolved then direction or additional support has been given and much appreciated .I do look for answers on existing threads as well so there are things I have found out remotely. I have owned over 40 cars but think I know more about my R230 than any other car
If I treat this as an Oscar type nomination then the short list would be Televison,SL55,Turbopete,John Laidlaw although I am sure I will have missed someone, Dont want to open the golden envelope to name the winner as it would be wrong to name one person but maybe it will be on Television later[did you see what I did there?]
Thanks to these and other guys who have helped me
daibevan
Alltwen, Pontardawe
W203 C200 Kompressor Elegance SE 2006 Tanzanite Blue with cream interior
Malcolm must be related to Uri Gellar.
My nearside mirror indicator stopped working and a fault code popped up. I assumed it was a short and asked for help on doing the job. Malcolm emailed me the instructions. The fault disappeared and hasn't happened since. I have delayed this response in fear of sods law, but thought you should know about this superpower.
Birmingham
G55AMG/2012/5500
Once I posted a problem with my gear and got some useful suggestion from fellow members. My bad I couldn't imply it.
Pullman
ESSEX
1981 500SL_1999 500SL_(2002 CL600 sold) 2003 500SL
ABC help
Have been given loads of help and advice on ABC issues on my W215 CL600 with regard to pump, front valve and damper which enabled me to rectify the faults. Cost to me was parts only where the s/ex pump was the most expensive at £425. Many thanks to all.
sineda
East Midlands
Mercedes B180 CDi SE
Definitely! I've fixed my rear washer jet. Fixed the tailgate boot mechanism (was corroded and the electrics didn't work). Now GLK has kindly provided me with some pictures that shows the rear seals under the bumpers - DYI job to get rid of the water building up in the spare wheel tank.;-)
such
Sunny Essex Coast
W212 Eclass 350 CDI Sport 2012
Preventative maintenance - replaced red turbo and breather seals yesterday.
Would not have attempted had it not been for this forum, so a big THANKS!
rexemper
Berkshire
R230 SL500 - oh yeah!
Replaced boot lid struts - would not have tried that without the helpful advice on this forum.
Many thanks.
Craiglxviii
Cambs UK
Almost all of my MB problems have either been fixed by, or diagnosed by and thus enabled me to get fixed, via forum posts on here.
ZZZZ
Same here - too numerous to mention, always great advice.
As one example - I put together a DRL mod entirely thanks to help and support from Malcolm (television) and Chris (area51).
rexemper
Berkshire
Managed to clean and flush the boot drainage on the SL through some advice on the forum. Hadn't even found the drainage points before!
Big thanks
