HELP: Rear Parking Sensor Pushed in (damaged)...
jig
Essex
mercedes/2001/5.0
My car(W220) has had one of the rear sensors pushed and it is sitting in the hole, feels a bit springy. The car goes mad each time I stick into reverse so have switched them off but this makes parking impossible!
What is required to repair? Is it easy for a compentant DIYer or a stealer job? If stealer how much would they charge?
Thanks in advance.
Jig
barry jones
Warrington
2016, LWB W222 AMG Line S-Class S350d - W415 Citan Van too :)
Jig,
The bar that holds the rear parking sensors only clips into the rear bumper and can be popped out to access the sensors behind.
The individual sensors clip into little posts in the strip and as the plastic is quite soft; it will probably have just come unclipped and won't have damaged the clips at all and should refit really easily. Just been and took these for you
Baz
Looks like this...
Pop the trim out a little...
Heres the sensor in its little housing
A few different angles of the sensor housing.
Not got round to wiring mine up yet!!!
Thanks Barry for those fine pictures
jig
Essex
mercedes/2001/5.0
Thanks Baz, really kind of you to take those pics. That really helps I will gently pry the strip open and take a look, fingers crossed I can just clip it back on!
I got a feeling that there maybe slightly more damage as when I look at the hole at the moment it has a bit of plastic remaining where ever the sensor has broken away from!
Will let you guys know how I get on.
Jig
jig
Essex
mercedes/2001/5.0
Guys, any tips on ways of prying the bar open? Worried about paint and clip damage!! any tools I should be using??
Jig
jig
Essex
mercedes/2001/5.0
anyone? want to give it a go today, before sun down :)
jig
Essex
mercedes/2001/5.0
Managed to pry open with a cake/kitchen plastic spreader!!Bad news was both of the top plastic parts which fit into the holder were broken :( fitted the into the bottom, and taped across couple of times not the strongest hold, will wait until it falls again and will have to change next time..
Is the sensor holder available by itself?
Cheers
jig
Cole@MBS
www.mbssouthampton.co.uk
Dont belive you can buy just them, can you not stick them back with a good glue/sealer?
jig
Essex
mercedes/2001/5.0
Thanks Sam unit, but there was only one, the other one was missing, what glue would hold securely? Would it be secure enough with just one?
Cheers
jig
Impact glues are the best due to their rubbery nature, instant glues can be very brittle
barry jones
Warrington
I am breaking a 2002 S500 LWB and have a bar available in black. It has a few scuff marks and will probably need repainting to your colour but all plastic bits are intact. let me know
Baz
jig
Essex
mercedes/2001/5.0
Baz
Thanks Baz, will try the glue approach, if fails will let you know... thanks ps may be in touch for some other bits that you are breaking..
Cheers
jig
teddycatkin
cheshire cheese country
Hi Jig--assuming the sensor is now working OK ? (just a broken clip)
Use a good blob of bluetack on the inside to hold it in and a small spot of super glue just to position it and hold it in hole first.
I know they are fiddly things to mess with if you have not got a ramp- but once done it should be ok again.
lutters
East Kent
2004 W211 320cdi
w211 front parking sensor intermitent
Hi all,
Have an intermittent front offside sensor problem after washing or in rain. How can i remove trim to look at sensor?
John
barry jones
Warrington
The trim is held in pretty much the same way as for the rear sensor trim. just be aware that if your car is a facelift one, the trim has angled clips at the front which slide into and under the holes in the bumper and as such, should just be removed from the side of the bumper first. Pre-facelift cars just clip in and can be popped out from any position
Baz
celina12
Hello All,
thanx
celina
Parking Sensor
Hello All,
thanx
celina
Parking Sensor
Hello and welcome to the forums :D:D
Hertfordshire Merx
A160
Also make sure the connector doesn't contain any water, they can be prone for that.
Coulsdon Eagle
Bexhill, East Sussex
Sprinter 310CDI
if the clip is missing, just use a bit of clear silicon sealer instead of glue, hold it in place with some tape until it's cured, unlike glue, any excess silicon on the plastic trim will come off easily without leaving any marks on the paintwork, job done!
lyesba
New Registration
Rear bumper sensor trim w220 non-facelift - please how can I remove it
Two of my rear sensor have popped inside as my car was hit at low speed, I want to put them back but I am struggling to remove the rear bumper sensor trim.
Please let me know how I can remove the rear bumper sensor trim from a mercedes w220 non-facelift without damaging the bumper.
I have tried to remove it but it doesn't come off and if I try harder it will damage the bumper.
Please let me know if there is a special technique or tool to use to remove it.
Mercedes dealer told me not to do so as I will damage it and want to charge 120 GBP for that?
Please let me know
Cheers
