How to remove torque converter
Torontocity
Toronto
M.b.300SD
Hi All...i have a 84 300sd...took out engine and transmission..i need to remove the torque converter, there is no bolts or nuts that is reachable...how does this come off ? Thanks..........:confused:
Hello and welcome,,is that a 123 or 126 please
brianbrian
cockney in the West Country
w124 250D, SL129-deisel
At the back of the engine is a small plastic cover, prize this off, you need to rotate engine so you can undo the six bolts individually and the reverse when bolting it back, you will need a socket to fit the bolts, ( its not rocket science). Hope this helps
Number_Cruncher
1995 W124 E300D TE
One thing I would look carefully for on a 25 year old diesel is cracks in the flex plate - the relatively thin steel plate that the torque convertor bolts pass through. Check especially in the areas around the bolt holes themselves.
As the flex plate "flexes" each time the engine turns, I can imagine that the plate has seen many fatigue cycles by now, and some flex plates on these engines (OM617?) have been found to be almost dropping apart!
T
Torontocity
Toronto
M.b.300SD
Thanks all....That helps a lot....
