Hi Pieeater lost a lot of photo's when my hard drive crashed could only find a couple !! iv'e tried to zoom in on the last one might give you a better idea dead easy to do both the wing's and bumpers have a bit of tolerance if your holes are slightly off when you do the final alignment
Please give me some tips / ideas on how to remove the center console without causing any damage. It looks like this is the only route to do this restoration properly - rather than using a marker!
hi mr maniac , I own a lovely x -reg slk 320 , had since march , question, the nearside suspension seems to creak like an old floorboard, I had radius arm tightened and 2 suspension arms replaced by a garage back in july, but the creaking noise appears when I get out the car, I don't have a manual ,but still confused , can you shed any light on my plight ?
many thanks. mark b
Hi Mark with creaking suspension the best thing to do is get the car over a pit. a 2 post lift is pointless as the suspension is hanging and a 4 poster clanks about too much when your bouncing the car while checking !! over a pit all the suspension is loaded then its a case of one bouncing up top and one in the pit having a grope around, if its a dry joint or bush it should be fairly evident feeling around, sometimes a squirt of WD40 can be used to confirm the offending component !! older MOT centres usually still use pits for testing i'm sure a Christmas drink will get you a diagnosis
Comand Online Ltd is a specialist supplier of Mercedes Navigation Disks,
Phone & Bluetooth, iPod, DAB, CD and other COMAND retrofit parts to
enhance your vehicle.www.comandonline.co.uk
