If you dont have the contact plate then you will need a phone system retrofitted. These vary in cost depending on what you want from the system. Email me the VIN number of the car and I will advise further for you; sales@comand.co.uk
The mCar system has a pin code for pairing which is 0000. The Mercedes cradles have a pin code which is 62872, except the SAP cradle which has a pin code generated (16 digits) at the time of pairing. The viseeo MB4 has a pin code of 1234.
The built in bluetooth option on an NTG1 comand unit is no good for any phone. Yes you can try pairing and it will ask for a pin but you will never get a phone to work with it. It wasnt designed for phones and was removed when the car would/should have had the latest firmware applied to the headunit.
