It's a bit sad when...
Rob76
Coventry, UK
S211 E280 CDI Sport
yup!!!!! i remember when they launched variable height suspension on LR in kenya ,did a run around the national parks ,came back up the Mombasa rd all tipped on one side as most of the pipes had chaffed thru when off road. just imagine how this latest rubbish will perform . chelsea tractor thats all.. gest off roader G wagon,next best L cruiser both pre 1990 and all the electronic crap, i have some idea ,having done the africa bush thing for 30 odd yrs.
A guy i used to work with spent 30+ yrs in SA, said taking a new LR/RR into the bush: Forget it
You can take it in... :rolleyes:
ajlsl600
france
i remember when lego was simple and i had enough of it to build a housing estate ! or anything else, that i wanted at pocket money prices. not just one or two things at 90 quid...
ajlsl600
france
I've had my jump leads about 30 years. They were made by a mate of a mate from welding cable .... and they're long enough that you don't need the cars virtually touching. :)
welding cable the BEST way as is a cable link to the 2 jaws so spring dont anneal with heat and wreck clamps
  • #30
Mine are fitted with a pair of Anderson connectors. Allows safe and rapid connect and disconnect plus when I had a Defender I had a permanent connection to the battery with an Anderson connector.
rorywquin
North Yorkshire
An old B-Class.
Yep they are the best. We always had issues on site with welding cable vanishing.....maybe your mate was involved.:)
ajlsl600
france
had to jump that often ?
ajlsl600
france
Not really but the battery was under the passenger seat which being non standard meant it had to be removed for access.
got u... just out of apprenticeship i had about a yr on overhaul of construction company's site lr,s ,110 88,90 and in those days lr could not make up their mind, A/F whitworth and even metric were involved ,eventually disassembly involved the gas axe!! not my favorite memories always missing skin ! and whilst i would agree that a lr would with some intervention get you home they were without doubt an old mf that wore a garden shed..... we have a friend who bought one 4/5 yr ago and replacing a £5 seal on top back of eng cost him a grand as it was determined as a body off job !
ajlsl600
france
4WDriving/offroading seems to work batteries over and there is always someone that will need a jump start or some sort of boost.
must admit one of the more useful features of my ml250 blutec is the built in jump terminals under the bonnet surprised really that was not an extra? or maybe i should worry as to why benz deemed it ness ?
V6Matty
Newark, Nottinghamshire
Because the battery is in the boot and if said battery was dead you wouldn’t be able to access to get it on charge,
Adamki83
Mercedes E-class, 2005, E270CDI (2.7) + 1992 Mercedes 500SL (R129)
Craiglxviii
Cambs UK
Good jump leads are expensive.....;) mine are ****** heavy!
I just found my (brand new untouched) ones. They’re damn heavy when specified for a 5 litre engine!
rorywquin
North Yorkshire
An old B-Class.
I had a 4.5L Diesel (LandCruiser) when I purchased mine........the car had 2 big cranking batteries and I assumed that if I ever need a jump, I'd need good cables.
