Jack Pad or not when lifting vehicle
David White
E250 Bluetec S212 2013
I was just wondering if i am missing something, i
I bought a couple of the 'Mercedes fit' Jack pads for inserting into the jacking points but they dont seem as safe to me as simply jacking on the side of the plastic jacking point.
Alternatively jacking the car from the centre jack point i place the axle stands to again align with one of the sides of the plastic jack point, (same as pictures with the trolley Jack) rather than inserting the rubber adaptor.
Sure the jacking point gets a couple of indents fron the trolley jack but otherwise seems OK to me.
Can anyone share clarification as to which is the best way to do it
So which is better with or withjout the adaptor>
I just go straight under the jacking point with a trolley jack - not had any issues
NBurns
Sunny Hampshire by the sea
www.facebook.com
A180 CDI AVANTGARDE SE CVT,169.007, 2009
View attachment 86085 View attachment 86087
That reminds me, once my finances have improved I must get the rubber pad to fit onto my orange metal part also. I need a bar first for my trolley jack as mine suddenly ‘disappeared’ while on my ex’s drive.
Save your pennies, small piece of scrap wood will suffice
malcolm E53 AMG
A lot of the modern low access trolley jacks have a flat lifting bed with a rubber insert but as above I use a flat 4x2 inch piece of wood to stop any indentation on the crossmember
If i had a block of wood
Go for a saunter, you’ll no doubt find a bit of broken pallet wood by the side of the road ;):cool:
Wearsafoxhat
Plenty of building going on around here, lots of skips about….
I use one of those blocks that fit inside the Jack point on the E class as it has the indentations.
NBurns
www.facebook.com
Richard Moakes
Newton Abbot, Devon, UK
CL500; ML500
Compared to these on Amazon…..
Jack Pad, for Car Lifting Platforms, Trolley Jack, 4 Pack, Black https://amzn.eu/d/cg1lCIE
They are pricey, but the key feature is that they lock into the receptacle on the chassis and then you manoeuvre the jack under the pad, makes life easy.
D
David White
I used a similar one to these on the front center jack pad on my E class, after jacking, whilst placing the axle stands under the jack points the car fell off the trolley jack and luckily was caught on one side by the axle stand I had put in place..
I think that the trolley jack had hit a stone which stopped it's rolling motion towards the rear of the car purring a pulling force forwards on the pad..
I was lucky .. no damage but it made me question anything placed on top of a trolley jack between the jack and the car itself
I guess it was my fault, and I am extra vigilant every time the cars wheels are off the ground now
ajlsl600
france
I just centre my trolley jack to the existing pads, jobs a good un. Simples, or as above a bit of scrap 3x2 sure f not buying anything specific.
D
David White
Direct contact or wood is the way to go for me.. I think that the additional rubber pads add unwanted extra flex in the support.
Mercedes put a pad under the car to protect the car the additional pads in-between the on car pad and the jack are a failure point in my experience
NBurns
www.facebook.com
DSK
CLS 320 CDI, S350 Bluetec
Rather than start a new thread I’ll ask here as it’s the same topic.
I wanted to buy the pads below but a lot of those, whilst listed for Merc, do not include the w221 in the application list, despite it looking like it will.
Does anyone know if these are the same across all Mercs with this?
malcolm E53 AMG
I’m pretty sure jack pads are standard across the C/E/S range but a good idea to measure the indent on your jacking points and contact the supplier for exact measurements
  • Like
Reactions: DSK
DSK
I have used a block of wood for years.
This is for keeping in the boot and when the car goes for an MOT/Tyres they can use this, is my thinking. I am concerned how that hole got there in my floor. There is a good possibility the tyre place who balanced my wheels my have jacked it up incorrectly.
