i have a c class 51 plate it has a tiptronic gearbox the problem is it seems to jump into neutral when approaching a juction or roundabout it also seems to stay in gear ie second and the revs run high help
Hi Stevie, the plate is about £130 from MB and requires draining down of the Transmission to fit, so might as well change the fluid and filter at the same time, - the electrical connector (£20) too while you're there. Probably looking at about £250 to £300 from an indy or gearbox specialist.
Stop looking for the Best Garage!! We are here
and have the best advanced solutions for you,
at Competitive prices.
Put us to test with any issue you may have.
