Key will not turn...
N
Naraic
2005 CL500.
  • Moderator
  • #41
It sounded as though the metal worked in the ignition and that just cannot be so and that is why I asked :D
The flat key is the valet key...with no buttons nor batteries.
barbeds
cheshire
c240 elegance estate/2000/2.6cc
As suggested your keys are broken...and can be fixed.
But, now that your flat key doesn't work I would suspect either the EIS or the ESL (steering lock). When you put the key into the EIS you do not hear the steering lock whirr and release...so probably the lock. See my earlier posts as to what I did.
on one hand I can agree with you, but on the other hand neither of the button keys made a noise when they went into the ignition when the flat key was working.
N
Naraic
2005 CL500.
  • Moderator
  • #43
Did the button keys turn in the ignition?
barbeds
cheshire
no the button keys have never turned in the ignition, they have never made any sound when placed into the ignition either, they will only open the doors, the coils are snapped off.
barbeds
cheshire
as an additional thought, is there a fuse that could cause this problem.
N
Naraic
2005 CL500.
  • Moderator
  • #46
Send one of your keys to Malcolm. When you get it back, if it will not turn suspect the EIS or the ESL.
barbeds
cheshire
Would you care to post one to me,,, one that has not been touched or taken apart
Malcolm, sorry bud I missed this post last night, my head is pickled with this ****** problem, I will gladly send you a key, thank you, but do you have a coil to repair it with ?
barbeds
cheshire
right, I am thinking exactly the same, working from a known good key, once I get it back, if it does not turn then it is as you say EIS or ESL, but if it is either of these how do I know which one, and are they straight forward to remove, bearing in mind I cannot turn the key.
N
Naraic
2005 CL500.
  • Moderator
  • #49
You can easily remove the EIS....there are slots around the bezzle...insert two screwdrivers opposite each other and unscrew...then disconnect from the loom.
Someone competent can then test the EIS...if it works, it's the ESL.
barbeds
cheshire
Okay, looks like I have a plan of action, feel like the weight is being lifted already lol, Malcolm I will need your address to send you my key, cheers
PM replied to.
barbeds
cheshire
Malcolm PM replied to, need your e.mail for paypal payment
You will get the key by 1pm on Tuesday :D its signed for delivery.
barbeds
cheshire
right, so fingers crossed, its just my key, and tomorrow when I get it back from Malcolm and put it into the ignition, it will burst into life, but if it doesn't then its stage two, which is (I presume) removal of the EIS and have it checked with the key by a competent person, as previously advise, but who do I need to check it ? do they need specialist equipment ? ie star, what sort of price would I expect to pay for this check ? and finally can anyone recommend someone in the crewe/ Nantwich area. thanks Eddie.
The transponder coil had broken off, a new one fitted and held fast with hot glue, these keys do not like getting dropped.
N
Naraic
2005 CL500.
  • Moderator
  • #58
Would it be a good preventative measure to add some hot glue to an otherwise intact key?
Indeed yes, you cannot put it outside edge, or the pcb will not slide back into the case, but you can on the inside and the other components will hold it on, while the glue is still hot you can flatten it with your finger. Instant glues can all break.
It only want a tiny drop.
Just apply it between the square white/yellow cap and the coil
barbeds
cheshire
Yes Malcolm, I assumed it had from the rattle of the key, but that key had never started the car from the day I purchased the car, indeed both button keys were dead, therefore that broken coil is not a definite answer to my problem, however your repair now tells me I have at least one good key that "should" start the car, and if not I know I can move onto stage 2.
