M276 C350 disptick tube bracket?
MarinB17
C350 Petrol MY12 Estate
Just checking the oil on my new to me C350.
I found the dipstick tube waggles around.
This is a pic of the top rear of the right hand side of the engine
You can see the dipstick tube with a bracket attached with a hole in it
You can see there is a tab on the engine block with threaded hole.
It looks like there should be a bolt holding the bracket to this threaded hole.
Now i can't get the bracket into position over the hole, its maybe 15mm higher than the threaded hole.
Almost as if there should be a spacer between them?
You can see my dipstick tube is angled unlike the EPC diagram - and it looks like a bolt should just go through there:
The car has had lambda and NOx sensors recently so I assume something has been left off....
Should I just go ahead and manipulate the dipstick tube down to the tab on the block and stick a bolt in?
Anyone else got this engine can take a quick look at how the dipstick tube is secured to the block at the top?
Thanks.
M
MarinB17
  • #2
Nobody else have this engine can help me?
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
you say bracket is attached to dip stick , if this is the case then if you put a stud in the bracket will you still be able to remove dip stick without removing the stud. ?
mercmancdi
Just to add it would be easy enough to put the spacer in , as long as it’s the correct dip stick and hopefully the previous owner had not stuck any other dip stick in from different car.
Could you search for a new dip stick for your car online and it might show the length then you could measure yours to check its correct length , perhaps there’s a 15 mm stopper that slides up the dip stick and makes a collor at the top
this would also take the slack out of yours if this was missing.
mioba
Nottingham and Köln
I would go to the dealers. explain the problem. they will show you the IPL. you figure out whats missing and take ot from there
Jim2
1st Merc 2010 E Class W212 2.1 CDI. 2nd Merc 2014 E Class W212 220 CDI 3rd Merc 2018 E class W213
The EPC diagram shows 2 retaining brackets, one up high on the tube and the 2nd down where it enters the sump...can you check if both of them are in place???
M
MarinB17
Right thanks all for looking in and helping.
I took another look, higher up there is a bit of thread poking up with sharp end, almost like a bolt has sheared off.
The bracket on the dipstick tube would fall perfectly on this.
However the looms above would then block the dipstick handle. But they don't look routed correctly to me, clips are not home and theres some rubbing gone on.
If anyone has this M276 engine would you please please be able to take a photo of this corner for me and see where the dipstick tube fits to the block?
The car was worked on my a very well renowned specialist who replaced the lambda and nox sensors below this....I don't think they've put things back right. Unfortunately they are 250miles away from me now.
M
MarinB17
Got this pic, my harnesses are routed wrong. Need to put it right....
