mechanic cut hole in my car!
coolpot
c180/2002/1.8p
Hi this is not a merc its my ford, but i just got my car back from having some work done, its had two new anti-roll bar Drop links as i call them?! i think it links the subfram to the top of suspension or something or other! i duno!
and its had the rubers that the roll bar sits on changed - one of the subframe bolts apparently was spinning, and i have a pic as to how he cut a hole in the side of some piece to get at the bolts
pic attached, how would you feel if this is your car? would you accept this as being the only way to get it sorted? i kinda feel a little unhappy i wasnt told before he cut the hole, and indeed that it has been left like this. just interested to know what you guys thinks, thanks in advance, steve.
Cole@MBS
www.mbssouthampton.co.uk
Theres better ways to remove a spinning bolt than that!
rf065
Grossbritannien
Is that metal he has cut through?
Russ
C
coolpot
c180/2002/1.8p
yes, dont you think it will rust? theres lots of "clean metal showing"
C
coolpot
c180/2002/1.8p
lol dont tell me that !:p
rf065
Grossbritannien
I would demand they replace whatever they cut through no matter what it costs.
Russ
Looking at the bolt under the sub frame, that has been removed to lower the frame to get access to the roll bar bolt.
It is load bearing
C
coolpot
c180/2002/1.8p
well thanks for all your thoughts, and info :)
I wil ahve to speak to him tomorrow!
Quick Silver
Moonshine Island, surrounded by water
R129 1990 SL 300..
Thats a bodge if I ever saw one ,That should make the car an MOT FAILURE now .
Cole@MBS
It will, bad rust 12 inchs near any load point will fail, think a gapping hole will just about do it
roofless
w124 e220 estate
it must be seam welded to pass the mot but i think i would use a new garage
teddycatkin
cheshire cheese country
I agree with the all the above comments-- but as its done now the rectification is to weld a good strong plate over the hole -they should have done that before giving it you back really.
100%Bitch
Norfolk 'n' good
I think if it was mine I would be going straight back to the garage and shoving the vandal's (he's not a mechanic) head into the hole.
These methods are no longer allowed in the UK
Uncle Benz
West Sussex
Mainly Mercedes
Sadly it sometimes becomes necessary to do this when the captive nut breaks free and spins, but it is very bad practice not to make the area good afterwards. It should have a small piece of the correct guage of steel welded in place, and a light rub with a sanding disc to smooth it all, and you would never know there has been a problem. Cavity wax injection from a cheap aerosol can will protect the inside and a squirt of underseal on the outside - good as new.
A good answer from a wise man, who knows what its like doing some of these jobs
