Mercedes A160 won't start
Ismand13
Denmark
Mercedes A160 - 2003, engine code 166 960- W168
Hello.
Yesterday when I got in my car, i couldn't start it, the starter works fine and the battery also, but it just don't start...
The only way I can make it start is if i pull the air filter off and spray brake cleaner, or something like it in. If i spray some short bursts of the cleaner i can make it keep running, after 30 seconds it can idle by itself. When the engine is warm it runs like normal.
My best guess is that the engine needs fuel when I start the car, so I'm thinking it's some kind of sensor, but not sure where to start. I tried putting a cheap tester on it, and it didn't say anything.
So hopefully somebody got a clue or have tried something similar
mattkh
England
A160 W168 1999 1.6
Is the mileage about 90,000 miles..?
area51
Kent
Year2000 A160
How old is the fuel filter?
mattkh
England
A160 W168 1999 1.6
It's a lot more, it's done around 300.000 km
Thanks.
At that mileage it can be a few things which you need to check/eliminate one at time.
What things have been changed in terms of fuel supply and fuel pressure during the life of the car.
I
Ismand13
Denmark
Thanks.
That's the problem, I've only had or for around 8 months, so i don't know the history. A Friend of mine talked about the air mass or a coolant temperature sensor, so i think I'll try the temperature sensor, it's a cheap part :)
mioba
Nottingham and Köln
It can expensive throwing parts at a car based on what a mate said and even what someone on a forum said and more so because the part is the cheap.
Use MB genuine parts, it will save you down the line.
I
Ismand13
Denmark
Thanks.
What is the outside temperature in the morning when you start the car...?
It's around -2°c
But I'll try change the sensor, if it don't work I'll go to a mechanic... Mechanic are just ridiculous expensive in Denmark
I
Ismand13
Denmark
Yeah i know, but the car is not worth any money, so i kinda wanna try avoiding MB mechanic and parts... They charge 1/4 of the cars value, just to do a diagnosis
mattkh
England
A160 W168 1999 1.6
It's around -2°c
Thanks.
Tell me more about where you think is the sensor you want to change.
I
Ismand13
Denmark
Thanks.
I've tried changing the coolant temperature sensor in the thermostat. I did it today, so i need to wait untill tomorrow morning to see if it works. It's a easy fix and a cheap part
mioba
Nottingham and Köln
When your car was running did it get to temp and at what temp didnit stay at. Thus trying to elucidate why you changed the temp sensor.
I
Ismand13
Denmark
Well, the car don't have a temperature gauge, only a light that turns on when it overheat.
Yesterday when driving home, it began complaining about overheating, even tho there was plenty of coolant on it.
So i found a guy who had a cheap universal tester, and the tester said the coolant temperature sensor was bad. But since its just a cheap tester i don't know if i can trust it. The sensor is only like 15 euro so it's a cheap part to try and change.
I was told if the sensor don't work, then the car don't know that it needs to spray more fuel when starting. If that makes sense.
So I'm just hoping that the change of sensor is gonna work. It only took 10 min to change
I
Ismand13
Denmark
I don't know how old that is, i have only had the car for 8 months, but i know i haven't changed it
I
Ismand13
Denmark
  • #17
Well done.
What Manual are you using to get instructions of how to change the sensor..?
U don't need a manual to change it. The sensor is hold down by a small metal clip and that's it
I
Ismand13
Denmark
  • #18
So... I've just tried starting the car, and it started right away like it used to do. Seems like the sensor change worked, so if u don't hear anymore from me, it's because it worked. I guess I'll first know when I've tried a couple of times from cold start, but its a good beginning
mioba
Nottingham and Köln
Good one OP. Do keep us updated to confirm. Fingers crossed for happy motoring.
Tel: 020 8863 9233
