ML270 Auto gearbox trouble!!!
Its leaking out the pilot bust, most common fault known to any 7226 box made!!
Thats the plug where the wiring plugs into the gearbox!!
£15 plug, bit of grease, couple of liters of oil!!
mrfuzzyfelts
  • #25
Where is this located?
Would lack of oil lock the gearbox in permanant LIMP mode?
mrfuzzyfelts
  • #28
Went to the garage today all happy to look for the PLUG etc and hopefully find the leak...
But as always nothing is that simple! :(
The oil is infact engine oil not gearbox oil! GUTTED
The car was 1ltr ish low on oil, cant see where its coming from atall!
My question is, would this or a problem with the engine cause the car to go into LIMP mode?
Or will the box only lock into gear etc when there is a problem with the box...?
So maybe I have 2 problems????
AHHHHH, i already hate being a mercedes owner! :(
kebo57
Lanc's
ml270
The car was 1ltr ish low on oil, cant see where its coming from at all
would this be engine oil our atf if engine oil I would expect a dash warnig light
if atf don't know about 1 lt missing, also there could be oil coming from under the inlet manifold working its way down to the bell housing mine does this but I never need to top up between oil changes 13500K.
I don't know this either I have had engine oil too low warning light with out limp mode.
I would say yes to this
I would say one problem
How many miles as your motor done I'll make aguess of about 140000k
mrfuzzyfelts
  • #30
Just had someone over with a diagnostics system....
Fault codes came up are:
013 - Speed Sensor
109 - Speed Sensor
110 - RPM Comparason
116 - Oil temp sensor
146 - inadmissible transmission ratio
147 - Gear inadmissible or slipping
Like he said 1 fault can then make multiply codes come up and i have no idea what any of these mean?
Anyway he cleared them all and car drives perfect now! :D
However im gussing it could be a 1 mile or 1000 miles before another fault happens and it does it again. As i havent actually fixed anything!!!!
Do clean out the sump breathing pipes,,crankcase compression can force oil out of the seals
kebo57
Lanc's
ml270
Hi Malc would you have the instructions regarding location etc for the above
Kevin
mrfuzzyfelts
  • #33
How can I find out what these Fault codes mean>>>
013 - Speed Sensor
109 - Speed Sensor
rpe2
Silchester
Assuming you have established that the gearbox oil level is correct, then it means the electroplate has gone.
mrfuzzyfelts
  • #36
Locked up again today :(
THis time i only got
013 - Speed Sensor
109 - Speed Sensor
Erros
Once cleared car drove ok.
Anyone shed any light?
Conductor plate needs throwing away, as richard said above!
kebo57
Lanc's
ml270
013 - Speed Sensor
109 - Speed Sensor
Erros
Hi if S-A-M / U-N-I-T says it shot then you need to change it our get someone to do it here is a thread about the solution to my auto box problem
http://forums.mercedesclub.org.uk/showthread.php?t=46442
it might be possible for you to do it yourself depending on your ability its not that difficult a job but I've never done it.
Kevin
mrfuzzyfelts
  • #39
I would give it a go, i have a SUPERB magazine article which I picked up whilst waiting in the Merc garage for them to check my oil.
Step by step guide!!
Part numbers are the only thing that worry me! and getting all the right parts
kebo57
Lanc's
ml270
Hi I'm a bit confused as you have got someone to check your oil but you’re going to tackle this job. ;) Only joking
I would like to see that magazine article
I have the box & the old electroplate plate so there will be some numbers there also Malcom might be able to help here wis & part numbers its well worth his imput (never have to much information)
Kevin
