ML270 / W163 Window mechanism
BriBar
The drivers window on my 2003 ML270 has stopped working. The motor is still going and I can pull the window up and down with my hand.
I removed the door liner / card and had a look in. The big semi-circular cog is still moving back and forward or around to be more precise, but it doesn't seem to be bringing the attached arm with it. The arm is still attached at the pivot point, but does not follow with the cog.
I assumed that there would have been a rivet or bolt of some sort between the arm and cog to carry the arm around, but I cannot see where it would go.
To top it off, the SRS light is now on. It think this is because I unpluged the door airbag when I was taking the soundproofing off to have a look in, can this be reset without a dealer plug-in
Can anyone advise me on these?
panason1c
Somerset, UK
The blind rivets in the centre of the pivot point have sheared (a known problem), you can remove the complete winder assembly and repair it by welding (as i did with mine) or buy a new one.
Unplugging the srs plug and then turning the ignition on while still unplugged (probably when you operated the window to see what was going on) will trigger the warning light , the only way to reset is a trip to the dealers.
ps..........the winder assembly is secured to the door with standard pop rivets that you will need to drill out to remove.
I guess you are aware that the illuminated srs light means the airbags are disabled.
B
BriBar
From what I can see (and I couldn't see very much), the mechanism is all riveted in, so I guess these all have to be drilled and riveted again. Does the whole window mechanism have to come out to do it (i.e. bars, rails etc.)
I was hoping there would be a turn the ignition on, close the door , put on the wipers and stand on one leg turn around three times and kick the back wheel sort of reset for the SRS code reset. There goes hope!
panason1c
Somerset, UK
See my previous 'edited' post............yes, remove the whole mechanism.........just drill out the rivets and the 'star' ass' should wriggle out, the rails/runners stay in place.
B
BriBar
There goes my Saturday
If you need any MB papers on doing this job just ask:D:D
B
BriBar
Anything you have would be much appreciated.
I will need an Email address please
2 sent,,,it is basically as Pano said.
If ever you need any info work sheets just ask :D
ChrisGarner1969
London
ML270CDI/2002
W163 drivers door window regulator replacement - ML270CDI/2002
I would dearly love the sheets you have on how to change the regulator and which rivets to use.
Please feel free to contact me on : chris@chrisgarner.co.uk
Many thanks
chris
ChrisGarner1969
London
ML270CDI/2002
Television - Thank you
I look forward to receiving them and thank you for your kind welcome.
This seems like a very friendly and helpful site.
Best
Chris
Best
Chris
Look in you junk box, they were sent out.
ChrisGarner1969
London
ML270CDI/2002
Malcolm,
I don't seem to have them, could you please send again?
Can i ask what email address they are coming from? (please feel free to email me personally so you don't need to publicise it)
My number is 07971 485007 if it helps.
Many thanks again
Chris I have re sent them, my computer sent them somewhere else, so sorry.
merridianmel
2002 270cdi ML and 2004 SL350
Any chance you could send me the work sheet for driver side window regulator replacement. Mine has also failed
No problem, just PM me with your Email address
FibroCraig
Worsley, Manchester
51 ML270 and X reg A160
Hi Malcolm
Can you please send me the worksheets for fixing the drivers side window as wee as mine has just failed. I'll pm you my email address.
Many thanks
Craig
I've not got permission to pm apparently so my email is craig.bradshaw@sky.com
