Nasty noise!
Streethawk
Grimsby :(
Got to Scunthorpe earlier and the engine started making a noise when I got of the motorway - a kind of sharp noise...
got it back (20 miles, quite gently) and dismantled bits - the plugs are clean(ish), there's no emulsion... So I had the cover off. evrything is bolted down ;)
the only thing I can even see to be astray is that the non-tensioner side of the chain is a little loose. but i can't see why that would make the noise that i'm hearing. anyway...
any hints of where to start looking anyone?
jimgod
mansfield
car might not like scunthorpe ?
joking apart obviously checked the obvious?
need bit more info on noise 1st
Streethawk
Grimsby :(
Def. not pinking. It's a kind of rattling clatter... taking it to a garage (YUK!) at 10.30 for a bloke to have a listen... don't have a lot of faith though ;)
roland cad 500
What about taking the belt off, seeing whether that stops it.
Could be the bearings, in the water pump or alternator.
Just a few ideas.
Or you could just video it, put the film on here so we can all have a listen.
Might be easier to suss out.
Cheers Roland
Streethawk
Grimsby :(
if it doesn't like scunthorpe it has plenty of taste
i wonder if i could record it and psot an mp3 here!!
Streethawk
Grimsby :(
Just a few ideas.
Cheers Roland
great idea about the belt - both pump and alternator recently replaced (gsf) - maybe cheapo crapo!
roland cad 500
Never know, could be duff.
It does happen from time to time.
Cheers Roland
Ps good luck
Streethawk
Grimsby :(
Cheers Roland
Ps good luck
ta for the luck - gonna need some!
had belt off - no difference. normal at first, then noise builds as engine warms.
off to garage now :(
Streethawk
Grimsby :(
Managed to find a decent old-fashioned mechanic and have a chat with him about the engine, then old cars, then all sorts of things.
anyway, he had a listen with a "stethescope ending in a screwdriver" and thinks it could be a worn cam or cam follower(?). he also said the car was too big for his garage so he couldn't do the work for me!
better get haynes out :(
Streethawk
Grimsby :(
what's a cam follower - no mention of it in haynes at all!
Streethawk
Grimsby :(
The unit that contacts the end of the valve stem and the camshaft. The follower rides on the camshaft and when the cam lobes move it upward, it opens the valve. Also called "valve lifter" or "tappet."
right. ****** techno-babble!
Streethawk
Grimsby :(
spent the morning under the bonnet - found the chain tensioner had stuck in its housing, freed it & now there is no rattling.
however, once the engine warmed up the "clacking" came back...
looks like i'm going back out there again now!!!
Streethawk
Grimsby :(
  • #17
have had the car stood for couple of weeks due to no time (but managed to get bike MoTd and taxed) - so went back out to it this morning.
inspecting cam followers - front rocker. putting it back & someone must have had this off in the past, cos when i got to putting the last bolt back in, it went most of the way then just went round & round. worried, i took it back out again and was right to be worried... the head thread was nicely lodged in the bolt.
as i had previously loosened all the bolts, i decided to retighten them all and another one had thread problems :mad:
looks like a very expensive job now... anyone want to make me any opffers for parts ;)
Streethawk
Grimsby :(
  • #19
mercmonkey said:
If you are on about the bolts that hold the rockers on, it can be rectified with a helicoil
http://forums.mercedesclub.org.uk/showthread.php?t=16387&highlight=helicoil
Ive had the same problem, local engineer (motorbike shop) quoted me 25.00quid per helicoil
finally a very nice man has re-coiled my holes !
suggested that noise might be from a blocked oil sprayer tube not lubricating the the mechanism - am going to put in engine cleaner and warm up the engine, then drain oil, change filter, remove the tube and soak it in gunk overnight, then clean out with oil, refit and refill engine, see how we go...
six months of waiting may be about to end...
Streethawk
Grimsby :(
  • #20
oil sprayer tube is fine, but i have tracked the fault down to the hydraulic tappets ... will start a new thread as this one is so old now, who will look!
