lakeside
- Dec 16, 2006
- S124/1996/280
When starting, cold or hot, you should not touch the throttle at all. It doesn't have an automatic choke, being fuel injected. Idle speed should be about 1000rpm on starting from cold, dropping to about 800. The idle speed is electronically controlled, and adjusted in conjunction with the mixture, whilst monitoring the co2 output. Also, the throttle cable adjustment should be checked. In other words, a Bosch injection specialist should do it. Depending on what part of Wales you live in, maybe another member could recommend one?
Glad your liking it so far!
