Oil / Fluid extractors
reminds me of the black cabs i used to work on, rivetted ladder chassis, leaf springs and those dampers look just the same.
dieselman
A diesel
Lever dampers were used for pretty well all Austin and Rover cars right into BL times, even the Austin 1300 had them.
I'm surprised to see a rear anti-roll bar though...quite some sophistication for it's day.
Frontstep
T210 320cdi
Theres a Bentley Spec garage at my house lined ceiling heater pipes etc and full of Junk, can't swing a proverbial cat in it, hey ho when we move.
My house isn't as clean as that garage !
me too, looks quite a modern design too - i wonder if this is another mod from the original?
47p2
Scotland
The ARB is original and Vauxhall bushes fit the drop links.
There is almost nothing fitted to the Rover that is not from the period. The electronic fuel pump would originally have been a points operated pump, the radio has been converted to FM although it retains its period look....Everything else is as original
grober
Scotland
W204 C200cdi estate
Does it have the dreaded oil Luvax-Bijur system for chassis lubrication or has it been converted to grease nipples?
47p2
Scotland
Fantastic wedding car :cool:
It's outlived most marriages already
Yes the Luvax-Bijur lubrication system is fully functional. The Rover was never designed to have grease nipples and tolerances did not lend itself to greasing the joints.
The oil container for the lubrication system can be seen in the picture below
grober
Scotland
W204 C200cdi estate
Glad to hear the original system is intact. Many were "converted":cry: when they went wrong I believe.
47p2
Scotland
It's really a simple device that works off the engine vacuum. There reeally isn't that much to go wrong with it
Number_Cruncher
1995 W124 E300D TE
and sorry to get off the off topic, but....
i used a vacuum extractor to remove the oil from a 271 engine in a 171 last monday. i also removed the sump plug to see if any further oil could be drained - not a single drop was to be had!! so subject to tests on other engine types i am now a convert and believer.
I too was fairly sceptical at first, beofre I tried one.
However, I know that being able to do an oil change and filter entirely from above while wearing smart clothes has enabled me to fit the job in around other "duties" where if the car had to be jacked up, and I had to get into working clothes to wriggle around underneath it, the job simply wouldn't have been done on time.
I think the ease with which an extractor allows particularly those DIYers without lifts and hoists to do quick oil changes is worth much more than the really academic argument about getting every last drop out - as the oil galleries and perhaps an oil cooler are still quite full of old oil, it's not something I can get too excited about.
indeed NC, it seems they get even more oil out than draining, but as you say it is a little academic really - i note your lack of excitement.
S80
North Lincolnshire
None at the monent, but there's an OM642 in the Jeep Grand Cherokee!
With Main Dealer service rates being what they are, I reckon they're pretty much the experts in 'fluid extraction' :p
