OM 654 engine vacuum system issues
ABBIE999
New Registration
E220d/2017/654
I have a mer E220d yr 2018. AN EML ligt came on, on taking it to the garage, i was told there was an issue with the vaccum pump. Has anyone had this kind of issue?
Hello and welcome
E220d and engine warning light… I‘ll take a stab in the dark of it being a NOX sensor failure instead…:(
What kind of garage did you take it to?
Has it been for a software update recently?
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
Was this a local garage, how did they come to this conclusion?
I would visit a Mercedes Independent garage.
ernieh
Scotland, East
It might be worth doing a search on here and on t'other side! I saw one recently where the brakes had 'failed' and it turned out to be the vacuum pump. Not sure of the detail but, if I remember correctly, it lives in the sump along with the oil pump, so is an engine out job to fix.
Ernie
ps. Happy to be corrected if the above recollection is wrong!
A couple of other threads running on this subject at the moment...
ernieh
Scotland, East
moj91
Northamptonshire
W213 E400d-T, W204 C250CDI-T, W220 S320CDI (AMG Kit), W168 A170CDI, W210&W124 OM606...
This is my thread for what sounds like it could be a similar issue.
IF you have suffered brake servo assistance failure as a result of your fault, make sure you report it to VOSA https://www.gov.uk/vehicle-recalls-and-faults/report-a-serious-safety-defect , as they are investigating a number of these issues.
Regardless, if the tandem vacuum/oil pump has failed internal seals (whoever thought this was a good design idea needs shooting) it is a v. expensive repair and i would be demanding MBUK covers the cost, especially if the mileage isnt 100k+
Good luck...Abbie?
https://forums.mercedesclub.org.uk/...pump-and-loss-of-braking.192491/#post-1973777
Tom Toohey
New Registration
E/2018/220d
Here is the thread I referred to above.
Ernie
Hi Ernie,
Can just back from a service last Friday, litle yellow engine warning light yesterday ( Tues) , took it back to the garage and the initial assessment is the Vacuum pump is faulty. Car is from Mar 2018, easy life etc... 45k miles.
Garage told me 3 other cars locally with the same issue, problem with parts availability I am warned. Engine has to be removed and re-fitted. 3 days work. Approx 7k quote.
As I am not in warranty, it will be interesting to see the view from MB.
Hi Ernie,
This is becoming another one of those regular failures MB put into the marketplace from time to time. Stand your ground and demand goodwill. 45k miles is unacceptable for 'the best'.
Tel: 020 8863 9233
