tlgbltcn
- Oct 19, 2024
- W204/2010/C200CDI
Hello everyone,
I've been checking the engine coolant level for a while since it reduced abnormally recently and if it's reduced I add it up to keep the normal level. Then I realized that there were oil leak signs under the air intake area (passenger side of the engine) as well. These are what I saw at first glance.
When I checked the engine oil level it was at the minimum level so I assumed that the leak could be 1-2 litre approximately. I removed the air intake parts to see it clearly and came across the following.
The most obvious traces appear exactly at the attachment points (in the picture above), but I cannot be completely sure. I suspected an oil separator hose, but everything seemed normal there was no sign of a torn or a deformation.
Do you have any idea as to why this might be happening? I'm still investigating the part that I've removed. There may be a leak in the marked area where the oil separator hose is connected. Thank you in advance.
