Uncle Benz
- Mar 31, 2006
- Age
- 53
- Location
- West Sussex
- Mainly Mercedes
I would perform a compression test on all cylinders first. Next steps depend on outcome of that.
re glow plugs - you need the engine hot and I'd be using plus gas... wd40 will do nothing... also a torque wrench is the best idea to not over do it... can't remember the torque value but it's TINY !!! 20nm is a long way overdoing if I remember correctly
FYI glow plugs and their control unit / relay, are service items and need doing around 60k miles
also read on here quite few times, people having issues with refurbed injectors (and that's with ones done by proper places)
Dunno nothin about bleeding through diagnostic star but it has a low pressure pump in the tank and a hose at filter which seemed to make bleeding very easy yesterdayIt may need bleeding properly via star
