Parrot Died :(
V6Matty
Newark, Nottinghamshire
OK so not a real parrot but my parrot MKi9000, it seems over the last few days it have been a bit intermittent on connecting to my mobile and music and then this morning nothing, doesn't seem to have any power even tried plugging in a usb to do an upgrade but still nothing there :(, now i actually paid for it to be installed so i'm not 100% sure where it may be wired into but i'm sure it will only have a couple of options? I'm guessing it could be a blown fuse or the wiring (hope not the unit it's self?).
I'm contacting the people that did the install and getting their opinion but in the meantime any ideas on where to check?
Thanks in advance
Triv
Bristol
A brace of s210 1998 e300 turborustbuckets. Toyota HiLux Surf kzn185 3.0L
It has ceased to be
V6Matty
V6Matty
It's pining
don't want to go taking things out just yet, was thinking more along the lines of where to check first (fuses) befor going and removing the head units to check the wiring at the back?
V6Matty
V6Matty
Resting then?
funny :p :rolleyes:
should have read your earlier post properly as well thought you said to check the pinning and not that its pining for me :confused::rolleyes::Oops::D
I do not think there are any fuses in this circuit
Corned
East Midlands
2005 S211 E320CDI Avantgarde
The problem is with the installation.
It should be clipped into place properly. It should never be nailed to its perch.
It could just be sleeping
V6Matty
V6Matty
that was my thoughts, must be a doggy connection somewhere :(
would nailing it to the perch not be classed as animal cruelty? :lol:
V6Matty
V6Matty
poked it with a pointy stick a number of times, still no movement
thats a shame, i wonder depending what the sliced into to get the switched power if that has blown a fuse?
Options on what it could be connected to?
I do not know much about these things unless the parrot has a fuse :(
bob 6600
Audi S8 V10, S210 E320 CDI (R.I.P.)
The old 3200's had 2 in-line fuses, my 9200 has one so I would imagine the 9000 also has at least one in-line fuse
If you do decide to pull it apart, you can leave everything connected and just check the fuse in the loom. If fuse is fine, at least you know the unit is duff
cleverdicky
MB
See if they used those little blue (other colours available) Crimp Wire Splicer.
Terrible things.
ignition supply is usually taken from the cig. lighter socket on a mercedes. IIRC my 3200 has inline fuses, so id imagine the newer ones would have them too, as it cant be certain that whoever installs any particular unit will have the sense to fit it to a fused circuit, and so inline fuses are fitted
Terrible things.
scotchlok connectors often do give trouble after a few years, yes. however, from a fitters point of view, its a fast easy alternative to wire stripping/soldering/insulating etc.
I soldered a multi socket adaptor to the back of my cig. lighter when I fitted mine, and now my parrot, satnav, phone charger etc are ALL plugged into the adaptor, and the whole thing is hidden in the dash behind the radio etc!!
pipmk
E350cdi Sport cabriolet
We just couldn't resist it could we?
"It's passed on,it is no more,it has joined the choir invisible,bereft of life it rests in peace, this parrot has ceased to be,it is an ex parrot!"
Rather gives our age away.
V6Matty
V6Matty
  • #20
It was a statement from Monty Python sketch the Dead Parrot. But if it is dead rip.
yes i got it later after i had already replied, i was being rather dense this morning, really should give up and go home today :lol:
