Please help c270 diesel stuck in gear
red_diesel
swaffham
c270 cdi
Hi, im new to this site but own a 2002 mercedes c270 diesel estate, was useing every day untill last week it decided to not change gear im pretty sure its in second maybe 3rd but i dont think it is, it will let me drive her up to 60mph nearly hitting the redline,
after lots of searching a main problem was the conductor plate/speed sensor, and the plug which plugs into that, so i replaced both of these with new parts, changed the oil new filter and no change, (gutted)
any help would be highly grateful.
Hello and welcome,,,,if not the conductor plate, that only leaves the ECU but I have never known that for this fault, lets see what some indies say
R
red_diesel
swaffham
c270 cdi
thankyou, and i did think the ecu as i was told there is a seperate ecu for the transmission, but id rather get some info from others before keep spending :(
see what replies i get and thanks for the info.
R
red_diesel
swaffham
c270 cdi
also just to note, the s/w button it wont let me change this when pressed, and the auto tiptronic will not work, it is just in D all the time, but stuck in which ever gear.
Those functions cannot work in the lock up mode, it will need STAR I feel to see what is going on
Cole@MBS
www.mbssouthampton.co.uk
When you replace the said items, did you notice a lot of oil in the plug that fits into the gearbox??????
Gkinghorn
Bournemouth
E350 CDI Cabriolet - 2011
When my c220 seized in gear it was due to it being full of oil I recall.... Dunnoe where it seeps in from but once drained and the leak fixed it was good as new..
Cole@MBS
I suspect that the gearbox control module is full of oil!!
With luck it can be washed out with lighter fluid and dried somewhere hot for an hour or two
R
red_diesel
swaffham
c270 cdi
which is the control module, are you talking about the plug some call the pilot bush, iv taken the conductor plate out of the car yet again today and made sure i located the speed sensor properly all looked well but took it out anywhere and put back, cleaned the plug with electric spray cleaner again and put back togeather refilled and no change,
but what is the control module and where is it located,
many thanks for all your help.
R
red_diesel
swaffham
c270 cdi
if u mean the plug was full of oil so was mine but i replaced the o rings and had her appart again today and all seems ok no more oin in the plug but the problem is still there, thanks for the info tho, highly appreciate it.
Cole@MBS
N/s footwell, lift the carpet which gos under the dash, there your see a metal plate, undo the three 10mm plastic nuts and move forward, the gearbox control is to the left with two long plugs.....
It is often in the passenger foot well, I can check for sure later, the whole harness will have oil in it, but most will run out, mine was oily but it did not affect the gearbox.
Please just repost here tonight to remind me
index.php
R
red_diesel
swaffham
c270 cdi
  • #17
is it to the left bolted the the metal plate, 2 plugs with long wireing harness on them, thats what iv found theres no oil on the wiring tho, but maybe its blown,
R
red_diesel
swaffham
c270 cdi
  • #18
index.php
great diagram, just nipped out and pulled carpet and plate out, there is a plastic control box connected to the plate so guess its that, theres no oil anywhere but maybe its blown,
Cole@MBS
Have you disconneted the plugs and checked inside????
R
red_diesel
swaffham
c270 cdi
  • #20
yep iv took the box out and its dry as a bone inside, iv got it here so i can search for one on the internet, but im just wondering do the serial numbers have to be exact or would others fit,
www.W140.co.uk&www.r129.co
