Please help c270 diesel stuck in gear
These are the ones listed, they are normally very oily inside
050 0255450532
0305452032
CONTROL UNIT,
Transmission control module
423
001 697
050 0325452232
0325453232
CONTROL UNIT,
423
001 066
067
068
069
050 0325453232
0355453032
CONTROL UNIT,
423
001 066
067
068
050 0355453032 CONTROL UNIT,
423
001 066
067
068
070
071
050 0305452332
0305453032
CONTROL UNIT,
423
001 050 030545303
0325451232
CONTROL UNIT,
423
001 525
050 0305452032
0305452332
CONTROL UNIT,
423
001
050 0325451232 CONTROL UNIT,
423
001 060
061
062
525
050 0325454232
0325454332
CONTROL UNIT,
423
001 074
075
076
050 0325454332
0345454332
CONTROL UNIT,
001 074
075
076
050 0345454332 CONTROL UNIT,
R
red_diesel
swaffham
c270 cdi
  • #22
050 0255450532
0305452032
CONTROL UNIT,
423
001 697
050 0325452232
0325453232
CONTROL UNIT,
423
001 066
067
068
069
050 0325453232
0355453032
CONTROL UNIT,
423
001 066
067
068
423
001 066
067
068
070
071
050 0305452332
0305453032
CONTROL UNIT,
423
001 050 030545303
0325451232
CONTROL UNIT,
423
001 525
050 0305452032
0305452332
CONTROL UNIT,
423
001
423
001 060
061
062
525
050 0325454232
0325454332
CONTROL UNIT,
423
001 074
075
076
050 0325454332
0345454332
CONTROL UNIT,
001 074
075
076
mine is the a0305453032 egs52 so same as one above, but mine is very clean and no oil inside either the plugs i also opened the unit and the circuit board was clean also. even the wires was clean on the loom, would i have to get the same unit with the exact same numbers.
A hard one for me as these are usually updated version, but it does not say, one with near enough the same codes could be OK
Cole@MBS
www.mbssouthampton.co.uk
Do you have a gear selection shown on the dash?????????
R
red_diesel
swaffham
c270 cdi
  • #25
yes it goes to D and R and P and N all fine, also shows the W above the D but wont change to S when i unplug the module box the W and D or whatever i have her selected in like N or P disappear but comes back as soon as i plug the box back in.
could the box be good.????????
R
red_diesel
swaffham
c270 cdi
  • #26
cant see it making alot of difference, but my box could still be good, no oil at all but there was loads of oil come out of the plug in the gearbox but maybe thats as far as it got.
Strange thing is these ECU hardly ever fail, was there a chance that you over torqued the screw on the pilot bush, its only 3nm
R
red_diesel
swaffham
c270 cdi
  • #28
thats possible mate, what would happen if i over-torqued it. ?????
Cole@MBS
If you have over tighten it, you wont be able to undo it, the nut will just spin in the housing!!! then you have to brake it out the plate and replace both.....
Steve@Avantgarde
Bristol/Somerset
Ummm lots of guessing going here and we havent had a fault code read or put up?
May I suggest doing this first, afterall it could be a failed battery with a severe loss of crank voltage throwing the gearbox straight into limp....it its the season for it now, plummeting nighttime temps are starting to kill batteries, I did 2 C Classes this week.
R
red_diesel
swaffham
c270 cdi
  • #33
iv had my own hand held diognostic scan tool on the merc but no faults where shown, would i need a merc one on her, also i put a multi metre on the battery and she is charging 13 plus when running.
R
red_diesel
swaffham
c270 cdi
  • #34
thats cool then i dont think iv over tightened her, iv had her off again today and the conductor unit out of the box again and put all back together,
Steve@Avantgarde
Bristol/Somerset
Very few hand held diagnostics read the gearbox ECU. With STAR you can look at actual value data of the electrics kit to see if its out of range, look at adaptation data on the gearbox shift elements and more importantly get a proper fault code!!
R
red_diesel
swaffham
c270 cdi
  • #36
Id like to thank everyone for there help in my mercedes, but today the problem was solved, so just for heads up for other people, iv heard many people ask the question when fitting a conductor plate or plug etc does it need going on the computer to have faults clear and most sites iv looked on said no,
today i had the merc on a diognostic computer and there was a few codes, from my old faulty parts so i had them deleted and hey presto, she is running perfect and smoothly,
Big thanks to television , Cole@MBS , Gkinghorn , Steve@Avantgarde ,
So thanks to all, great site and appreciate the help. :D
That is good news :D these Gearbox ECU only have a tiny memory
R
red_diesel
swaffham
c270 cdi
  • #38
i found that one out today :D there was 11 bad codes on just the gearbox, from the old conductor plate, the plug, also where i had un-plugged the ecu box etc etc but just happy its all resolved, thanks for your help mate.
