Possible EV.
ajlsl600
france
Nothin will get me buyin a duracells will be same as power tools always lookin battery after 2, 3 Yr and as seen will cost 2/3 of new power tool I'd like to see a 1980 based cost of 10 yrs motoring Incl car cost and a today version and see what the "real" diff is. When corrected for an average out of London salary then and now.
Chrishazle
Nr Ashford, Kent
I believe that even when a car battery pack reaches the end of its "useful in the car" life it can still be used in a solar/wind farm power storage facility, these are needed to cover for when the sun does not shine or the wind blow but the demand for electricity is still there.
rorywquin
North Yorkshire
An old B-Class.
A battery is made up of multiple cells (Tesla model 3 is about 3000 cells).
It is usually individual cells that fail in a battery leaving salvageable cells (by testing their internal resistance etc). Refurbished packs can then be made. They won’t have the ability to supply high current as needed for a car but will be perfectly good for storage and lower current applications like powerwalls.
Hotspur
R230 SL350
Wife just ordered an iX3
TBF I test drove one with her and it was actually pretty good...it's fine for her daily needs, commute, shopping, usual kid duties...but I think I will be keeping my petrol powered Merc's and BM's for the foreseeable...
Frontstep
T210 320cdi
A relative who bought a Hyundai Ioniq traveled from just above Preston to Wembley Stadium, spent many hours chasing around looking for charging points that worked.
The other issue is the car's weight appears to have been the final straw that cracked their delicate resin driveway when parked beside a laden van.
I think it is leased through her job and will be swapped at the first opportunity.
bladecrazy
bolton
tesla model 3 performance /honda cd175/w123 300d gertrude.
not sure what the hyundia wieghs but my model 3 is 2.3 t, i have zap maps which is pretty helpfull.
AndySlade
Tadley, Hampshire
C220 Diesel Estate, Sports Edition
I’ve used Comand SatNav to guide me to nearest petrol station when in need of fuel in an unfamiliar area, when away from home.
bladecrazy
bolton
I would say the driveway has not been made to any adequate strength to
handle vehicle weight.
i would say the same, i have my w123 and tesla side by side on imprinted concrete and its fine
Frontstep
T210 320cdi
Theirs is resin which isn't exactly tough stuff when you park a laden van and EV.
rorywquin
North Yorkshire
An old B-Class.
Not sure about that. We have 5 houses in our close (with all sorts of big and small cars) and one driveway is an absolute mess & the others are fine. He is a carpet fitter and keeps loads of carpets in his garage. He has a large van (not sure what the GW is) but sometimes it is down on the axle with the heavy loads it carries. House driveways are not designed for constant use with those loads.
oigle
members.optusnet.com.au
You could hardly class the average EV as heavy. My new EV6 weighs just over 2T. Just about any SUV is over 2 tonnes these days. My 2003 ML 270 was 2.2T Driveways should handle that weight. Poor design otherwise. Big loaded vans are a whole different ballgame!!!
Frontstep
T210 320cdi
As I said it is a "resin" driveway and they ain't up to much but look pretty (for a while)
What are the pitfalls of resin driveways?
Resin-bound driveways and surfacing aren't the best choice for areas that regularly endure heavy traffic and usage. While this type of surface course is quite durable and robust, wear and tear over time can lead to cracking. This cracking can potentially lead to further and deeper damage.
Theirs cracked in just over 6 months.
ajlsl600
france
Like all today, origional specc will be min std, not max. I will slab mine with 5 inch concrete and 6mm mesh. If on compacted stone base don't see further issue
I’ve a new yard that’s supposed to be min 175mm thick with 1 layer of mesh at least 50mm below the surface… had 10 test cores dug - some areas 135mm thick, some 220mm - some have mesh on the surface…
A previous yard that I was responsible for putting down was 250mm and 2 layers of mesh - had 600 x 44 tonne HGV’s a week turning on that one - it never broke up…
With pretty much any groundworks unless you’re there to witness it they’ll do almost anything as it can’t be seen afterwards.
ajlsl600
france
Tough. But that's hgv. I will never hsve more than 2.5 tonne likely much less.
