R230 SL500 Rattle
Jabberwock
There is a rattle from the rear (offside?) of my 2003 model which seems to be present when the roof is up but absent when it is stowed. I seem to remember seeing a post on this subject to the effect that there was a mod to replace some bolts in the roof folding mechanism. When I asked the service manager at the local M-B dealer, he denied all knowledge of this and merely suggested the car be booked in for investigation. Any thoughts?
A
andy@pcd-ltd
There is loads of modifications etc of the 230 roof system all for rattles knocks and squeaks etc.
The reason he denied all this is so he can hoover your wallet out for you when it comes to repairing it for you as they will try and charge you loads of diagnosis time on it.
I would personally take your car to another dealer or an independant where they will take better care of the car and not try to rip you off
I can give you the mod paper for the roof bolts and you can do it your self,,I have given out this paper more than 100 times
Details sent to you
Articpaz
SL500
Is it possible to send me a copy of that mod too?
Many thanks
Yes I can send it to you :D:D:D
Sorry I need an Email address please
dewimerc
Gwynedd
SL350 - 2013
Are the replacement bolts available from Mercedes and if so is there a part number?
The number is on the mod sheet,,about £4.75 each
dewimerc
Gwynedd
SL350 - 2013
Thanks - I'll PM you with my e-mail address if you don't mind forwarding the mod sheet.
Details sent :D:D
orb the Impaler
Lancashire
2012 SLK 250 CDi AMG | Volvo V70 2.5T AWD | MV Agusta F4 | 1999 YZF-R1
Hi Malcolm - could I have a copy of that paper too - you should already have my email address but I'll PM it to you if it has become lost in the depths of your inbox.
One mod that I *would* like to see is something to stop the roof (the actual outside part) rubbing on the rubber bits on the rear cover when the roof is down. It doesn't touch when the roof is down but must move slightly over bumps etc which is causing scratches. I ought to make a separate post about it with pics.
Yes please, a picture of the roof in the boot would be useful
I will send the paper on the bolts
Details sent :D:D Articpaz
Articpaz
SL500
Thankyou very much, is it just a case of putting the roof into the same position as the photo and replacing each bolt? no springs fly off or anything with the bolt out i presume!
congo
SL 500
WOW so many of us all with the same problem! MB should really be doing this for free. Malcolm may I please have a copy also? Ill pm my email address.
Panish
Bromley
SL 500
I have a annoying rattle also when the roof is closed, mainly from the passenger side and over bumpy roads. Any change I can have the details of the modification
Hello and welcome yes with an Email address and you can edit that out after you get them
