Hello,
Those pictures don't remind me what they looked like, but I do remember having the shifter dismantled and having to drill out some rivets on the large metal plate that covers it all.
It was a small black plastic clip that was actuated via the solenoid.
Well, I decided to try putting the car back together with the plastic clip removed. I also removed the metal arm as pictured above so the gearstick would not lock in neutral.
Unfortunately with it mostly back together the dash beeps with a red warning saying 'move gear selector to park' when the key is removed. Well, it is in park ffs!
Any ideas?
My R230 does this randomly when it is in park, starting it or turning the key often removes the message. You haven't got a flat rear battery do you?
Either that, or you did not plug the can connector back into the selector module.
Small 2 pin electrical connector (Stop/Start I think)
approx 6 pin electrical connector.
Well I have run the car enough for the consumers to come back online and then kept it running for about 30 mins after that but the message still comes up on the dash when I remove the key and then open the drivers door.
I will get it on star and delete all fault codes in case it has picked up any from things being unplugged, but failing that any other ideas?
