r230 srs light on
merk350
Newcastle
SL350 2005 with pano roof
The SRS light has come on with message saying please visit workshop.just wondering where to start,seat belts, seat sensors.also does it need to be reset with star disgnostics.
Very often its the connection on the passenger seat, it will still need STAR to turn it off
merk350
Newcastle
Thanks Malcolm I have looked under the seat is it the long connector to the right or the one on the left which has a yellow cover,thanks
I think just the long connector, it will be the yellow wires
As Malcolm says, very often the connector under the front of the seat. Look for the yellow plug on the far N/S (outside) of the seat.
merk350
Newcastle
Had car in today for diagnostics check on SRS,outcome was that the airbag control module was offline and needs replaced,also I was told it can be caused by the ignition switch being faulty,before I jump in and spend££££££,has anyone had a similar diagnosis.my indie said he has seen this before not to sure what diagnostic system he uses I assume it star any help would be grately appreciated.
Not easy as all CAN operated see if some techies answer
Very tricky for us to help, without being privy to the actual fault codes, and test data.
I would not say that was a common scenario though, presumably no communication was established with the SRS module?
If so, power supply, wiring checks etc are usually needed before condemning the module itself.
Not really sure why the ignition switch is being suspected here yet.
merk350
Newcastle
srs light on
Thanks for the reply Alex,When I asked what the fault code was I was told there was no code as there was no communicatiuon to the airbag module,I was told he had took out the centre console and checked the module wiring.The ignition switch came into the equation when he had checked his records of a similar car which he had worked on 2 years ago with a similar fault,and I was told that the contacts in the ignition switch start to arc this swithes the power to the airbag module off and on intermittently and eventually lows the air bag module.
Might be just coincidence but i was driving last week with the lid down and could here a rapid clicking noise coming from behind the dirvers seat not to sure if this is coneected witht the srs problem.The clicking stopped after a few miles.and every thing was normal.
The EIS is the master of the CAN,,if signal lost then no communication, but by looking at the CAN BUS on STAR you can see what is active and what is not
WG M-B
North west london
C63 Wagon in black
Clicking behind the drivers seat on an r230 is usually from the cd changer if it's playing up.
I would not expect an eis to cause this problem from experience, although you never know!!! I would be have to be sure the Sam is supplying the correct voltage etc etc
merk350
Newcastle
Hi Thanks for the info but ther is no cd changer fitted only front loading cd in the dash.:confused::confused:
WG M-B
North west london
C63 Wagon in black
Ok well is it definitely an electrical clicking noise???
There are only 3 relays in the box behind the seat, fuel pump, rear window and another, I cannot see it being those doing the clicking
merk350
Newcastle
yes it sounds like a micro switch clicking either in the seat belt holder at the top of the seat or maybe some hting to do with the anti roll bar,it sounds like tis from that area of the car.
WG M-B
North west london
C63 Wagon in black
Disconnect the plug from the seat belt and report back.
I should add the the SRS is not connected directly to the CAN
merk350
Newcastle
  • #19
Thinking about taking the car to another specialist for second opiion before I spend £££££££££££:rolleyes:
Not a bad idea, maybe they could look a little deeper into it
