radiator fan stopped working
SHIPSHIPS
My coolant light has now come on and says visit workship.
I have no power to the radiator fan. Does anyone know what fuse it is and where they are? anyone have any wiring diagrams?
Thanks,
Yes as above the car and year please
I posted that question to save you having to but I forgot you're going for the Guinness book... :lol:
I had not thought of that :D
Main feed and neg, P/W/M controlled by the engine ecu!!
Check the main 40amp fuse in the front SAM!!
SHIPSHIPS
Its a petrol. What is P/W/M?
Where is the SAM located in front?
I get the impression that all my problems are leading to the ECU`s!
Forgot to ask, should there be a perminant live with ignition off?
thanks,
thanks,
Front sam, ( fuse box ) under bonnet!
Pulse-width modulation Voltage control by the engine ecu!
Ign off, fan unit is dead!!
What use would that be Malc??
Apart from making the battery flat with-in 15 mins??
Once the car is locked down, its dead!!
Under very hot conditions the fans can start after you stop, or keep running,,many have the warning sign on them. It does have to be very hot, when you stop the heat runs to the outer surfaces
I see where your coming from Malc, theres more to it than that!!
I really want a fag!!!!!
Not had one in 8 days now!!:confused:
SHIPSHIPS
Ill retest the power with the ignition on tomorrow, if there is power then the Fan is knacked as the fan controller is built in!
Fingers crossed its something simple.
SAM was correct on his post,,I just wanted to give the warning that fans can start up on there own when the engine is hot
I will take a read and if you care to look back in a hour I will see what I can find to assist
SHIPSHIPS
HI and thanks for your help, i will keep a look out...
Its very simple to follow, a 12 volt feed, a earth, and a digital voltage from the ecu on the P/W/M wiring!
Sounds like rocket stuff, its so simple!!
I need another trip to St Lucia !!!!
www.ckinsurance.co.uk
