RCA - TV Cable
J
Jdokal
Mercedes
  • #21
Thanks again :)
They are just fine :D
J
Jdokal
Mercedes
  • #24
Nice one :)
I think you should set up a shop selling off your old components, your technical support is far superior. i.e by telling the individual what they require :)
Nice one :)
:D:D I have been doing it since 1947 :(
J
Jdokal
Mercedes
  • #26
Additionally, are all phono cables the same inside? i.e. is there a different cable to send a video output and for an audio output?
J
Jdokal
Mercedes
  • #27
Wow.....you must really love electronics :)
I bet electronics shop love it if you come in and tell them exactly what you want.
Nope all the same, ideally you would not use a phono plug on a video source, but they will work just fine,,,,the thing is the professorial cables are too large for car use and you cannot bend them to get a good neat job. you can spend ££££££££ on special gold plated plugs etc that have a cheap piece of cable in the middle
Do not coil any spare cable if you can avoid it
J
Jdokal
Mercedes
  • #29
Excellent advice, thank you.
One less problem once this is sorted.
J
Jdokal
Mercedes
  • #30
Parts purchased, installation after lunch and hopefully late afternoon we will have a working rear view camera. :)
I see the do remote things now using a video sender, that might be a solution in mine as the wires will be very hard work to get through the car
J
Jdokal
Mercedes
  • #32
link?
In order to create an earth, could I use the bolt thread from the light cluster? It goes through the body and is tightened via a bolt, if I place the wire between these two, should this work?
Yes that will be fine for an earth, I will find the link
J
Jdokal
Mercedes
  • #35
Hi Television,
I have an issue.
I connected it all up......and the screen remains blank.
I then disconnected the male rca for the video and touched it around the female connector. The screen flickers.....any idea how to get the video to work?
What have I done wrong? I do have another camera and it does the same thing.
You have got power going to the camera
The camera surely must have a live feed, they cannot be self powered via a video input
You can test the socket on the lead going in by plugging a standard video camera or signal from any TV video output
J
Jdokal
Mercedes
  • #39
Is the live feed preventing the camera from working?
Would my installation be compromising the circuit?
I had to extend the two wires that send the power to the camera.
Once I connect the video camera from the house and turn it on, should the navigation display?
You can plug any video source into the RCA female jack and you should get a good picture to test
