Resin Floors: The hardest wearing floor money can buy
Garagetek
MBO Forum Advertiser
Medmenham, Buckinghamshire
www.garagetek.co.uk
C Class
Recent advances in garage floor coating technology allow GarageTek to bring commercial-grade garage floor coatings to the residential market. Our Resin Floors provide the highest quality finish you can buy and uses methacrylate resin which is the hardest wearing of all.
This is laid as a four part process on top of an existing concrete floor, the four stages include preperation, a primer coat, the coating itself laid to a depth of 4mm and finally a sealant to give protection.
Benefits include:
  • Single day installation for a garage up to 55 square metres
  • Rapid drying times as it can be walked on 1 hour after application
  • Backed by a 10 year warranty
  • Seamless, hygienic finish
  • Easy to clean and maintain
With a range of colours available too, why not click here to find out more and see images of recent garage floors completed.
daveenty
The Frozen North :(
2019 AMG S Class Coupe
Any chance of a rough cost of this, or do I have to go through your website?
I have a garage just under 20 Sq Metre, with a painted concrete floor and I'm sick of the paint coming off on a regular basis.
Ta, Dave
G
Garagetek
www.garagetek.co.uk
C Class
Hi Dave
Yes of course you can have a quote. For a garage of 19-23 square metres we would charge £2,095 plus VAT.
We agree, paint can be very annoying!
Do let us know if you have any further questions.
Thanks, GarageTek
Ta, Dave
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Ta, Dave
Dave
DAVE
DAVE!!!!! you still with us or do I need to call an ambulance???
DAAAAAAAAAAAAAAAAAVVVVVVVVVVVVVVVVVVEEEEEEEEEEEEE
jib
daveenty
The Frozen North :(
Time for more paint I think...
I can buy an awful lot of it for £2.5k... Can't get the VAT back as I couldn't justify it as a business expense.
Sorry
Joe0675
BIRMINGHAM
2005 C220 CDI Elegance SE
My better half says the answer is Deck Paint like what they use on trawlers in the North Sea. It has fine grit in it to stop you slipping and it lasts for years, at least it has on our garage floor!
Xtractorfan
S class
If you paint over the bare floor or areas that the paint is lifting with PVA adhesive/Glue...thinned to the recommended levels, as stated on the container, then your paint will stay stuck for life.
Frontstep
T210 320cdi
Or for £2,000 tile it, or axminsters nice if you fall over :), heavy duty carpet tiles are nice a friend has had those with a spare box full for accidents.
Depends on how you use your garage.
daveenty
The Frozen North :(
I think the answer will lie in more floor paint. No way can I justify over £2k on what's purely a garage floor.
The garage's number one use is home for the Merc, and where it lives, though I do several other little jobs in there as well. The back room is a workshop, computers/electronics at one side so reasonably clean, whereas the other side has a shot blasting cabinet, so not as much so. I try to separate both halves, though the dust doesn't often let me when I'm using the cabinet.
The compressor is also in the back, but when I do any cutting/grinding/spraying this is done in the main garage so carpet tiles, as much as I'd like them, are out of the equation unfortunately...
daveenty
The Frozen North :(
Good find. :)
Will keep my eye on those, and they're not too far away either. May have to be two trips to pick them up, but possibly worth it...
Thanks.
