Restraint System SRS warning
MikeyBoy215
2005 W211 CDI
This is my first post ever here! I love working on my car, its a burning hole that i cant ever seem to fulfill!
I have an 05 W211 CDI. Im trying to isolate an issue that im experiencing after doing some work near the trunk fuse panel. So far, i got rid of the factory head unit, the factory amp, the navigational unit, and the racks.
I used the existing wire's which were on the factory amp, which supplied each speaker to the new unit. I also ran additional wires in the vehicles left side wire bay. Everything seems to be set up besides calibrating my sunroof, and a "Restraint System Malfunction" warning with an SRS dash light. :p
This is a project for me, and i enjoy it. But eventually i want to go for a full fiber optic delete but im stuck on this one!
If you guys or gals have any recommendations, let me know! I would love to hear.
Thanks!
There should be no interaction between any of the audio kit and SRS systems.
You can I let have dislodged a connector or powered up the car whilst an airbag was unplugged.
If you have a code reader capable of reading the SRS controller it will help pinpoint the issue.
pgh13
Nr Leamington Spa
E320CDI 2004 - straight 6 diesel
Do you know if the SRS fault is still present. It won't self clear but needs to be cleared with a suitable OBD2 scanner.
MikeyBoy215
2005 W211 CDI
That was it! Damn youre good! Let me check the fault through the canbus later this week. I appreciate you LostKiwi and pgh13
