Rough Running A170
Bob India
Bob India
A-Class 2005 A170 PETROL AUTO (W169) Facelift Version
  • #21
PROBLEM SORTED.
Today, I had another go at the car. I swapped ignition leads 1 & 2 with each other. Then waited for the OBDII code to change from P0351 to P0352 indicating that he HT Ignition lead I moved from cylinder 1 to 2, was faulty..
In reality, I should have done this right at the start, but was bogged down by the two error codes.
P0068 - Plausibility check of values for components B28(Pressure Sensor) and M16/6(Throttle valve actuator) in idle and under partial load. See above on how this was cleared by cleaing the throttle assembly first.
P0351 - Ignition spark insufficient at cylinder 1.
Some Background info.
This car is very low mileage. Used to belong to my mum who didn't drive it much. It's a 2005 car and in 2008 it had only done about 6,000 miles. Only used now and again. In 2008, my parents went abroad for 4 weeks. The car was left on the drive. One night I noticed a cat waiting by one of tyres. I moved the cat on. My parents returned, started the car and the engine was struggling and running Very Rough and shaking like mad. I managed to drive it to my local garage. They tried a coil from German Swedish French Parts supplier, (GSF), but no joy. Then they tried replacing Ignition leads on cylinders 1 & 2. still no joy. They gave up. So I took the car to Mercedes. They had the car for two days. I thought with their STAR diagnostics they would have the problem sorted in no time. On Day two, I told the Service manager, I wanted a diagnosis and was surprised they could not diagnose the problem in one day and that I wasn't going to pay for hours and hours of investigation !! We agreed a maximum amount. Later on day two in the late afternoon, he said the mechanic had noticed some wire had been cut above one of the ignition coils and that it would need a new wiring loop at considerable cost. I thanked him for his diagnosis and asked him to put the car back together. I picked up the car and took it to my usual garage. I took out the Air filter box and looked under the Air Tubes. I found what looked like chicken wings bones. Clearly, Rats had seen the car was not moving and had made their home under the air tubes, which is a hollow area in the engine. They had then proceeded to chomp through the primary coil supply wires. I bought some wire heat-shrink, trimmed the wires and soldered them. The car was back in operation.
We have a KFC and other fast food outlets at the top of my road. Dirty disgusting people eat their food as they walk down the road, or sit on garden walls and discard their leftovers in our gardens. I actually had my old Honda Accord in my garden which I was going to sell when I could get round to it. It was left in the garden for 6 months as I had bought another car. When I got round to starting the car, it was dead. RATS had chomped through the big bundle of wires coming from inside the cabin, to the engine. There was no way to fix the car without alot of expense and a new wiring loom. I had to throw that car away.
In a way I was lucky with the Mercedes. The rats had only chomped about 3 wires close to the ignition coil. Anyway, back to the story. I have read read on some forums, ignition leads should last at least 100,000 miles. This may be true for genuine leads. My mechanic had bought some CHEAP and NASTY leads from German & Swedish Car Parts. These leads were still in the car to this day. Lead on cylinder 1 had failed after just 25,000 miles. I had not realised the original genuine leads had been changed but I had been given the genuine leads and two cheap leads in a bag, which have been sitting in my garage for years. I put the original leads back onto the car and now the car is running sweet..
On a last note. When anyone comes to these forums looking for help and sharing their experiences, it is important to have a conclusion to their story when and if they resolve their problems. Even if they had to take their car to a garage. Let us know how and what was done to resolve issue. It will help the next person. Also, take a photo of your work progress. It's easy these days with mobile phones and auto uploading to Google photos..
I hope my experience and pictures helps someone else, and for budding mechanics who want to have a go themselves, you will need an OBD scanner of some sort. I used a ELM327 mini with the Torque Lite App. It won't do full and complex diagnosis like ABS and air bags and custom specific manufacturer features like the LAUNCH system will, but will help with some PowerTrain diagnosis. There are better and more comprehensive OBDII dongles and software, so it all depends on your budget..
Thank you all for your help and comments..
Regards
Bob India.
(I chose this user name after Ed China from Wheeler dealers.. You can learn alot from watching that program!!)
mattkh
England
A160 W168 1999 1.6
Bob India.
Thanks.
I noticed the mayonaise on the throttle butterfly, and guessed the car was used for short journeys.
Once a month, take the car out on a good thrash to stop that happening.
Regards
Bob India
Bob India
  • #23
Since my girl got her hands on the car, it is clocking up motorway miles and the service light is on !! Guess I know what I'm doing this weekend.. Another oil and filter change !
John Laidlaw
Wirral
Land Rover Discovery 4
Love the conclusion, thanks for sharing, as you say it’s good to see the end not just the beginning and the journey
icky
London England
www.youtube.com
Mercedes W169 2007 ML280.
Hi Everyone,
I would be grateful for advice regarding my 2005 A-Class (W169). 40,000 miles on the clock. I bought it new so mileage is correct.
Symptoms are; Intermittent rough running and car shakes.
The car starts OK, then it's like one or two of the cylinders are turned off and the car starts to shake. Then a few seconds later it's OK again. This process keeps happening every few seconds, (Between 5-10 seconds intervals) and is getting worse. This happens up to around 40mph, then going above this speed, say around 50mph and above, the car seems OK. Also, I can't seem to do more than 70mph, the engine tops out at about this speed.
I'm guessing the ECU is switching something ON and OFF and cycling depending on a reading it is getting from some sensor..
I went to my local NON Mercedes garage and they used a LAUNCH code reader which gave its reading as codes ;
00F6-008 Plausibility check of values for components B28(Pressure Sensor) and M16/6(Throttle valve actuator) in idle and under partial load Lambda control OK.
00F6-004 Plausibility check of values for components B28(Pressure Sensor) and M16/6(Throttle valve actuator) in idle and under partial load Lambda control OK.
Given the symptoms and the diagnostics codes I have been given with the explanations, does anyone know what the problem is or where or what I should be changing?
I would appreciate help from those who have had similar issues and what was done to resolve the issue. I do most of my own car repairs so familiar with most aspects of repair.
Does anyone know what B28(pressure sensor) & M16/6(Throttle valve actuator) are? I have an idea of what the Throttle Value Actuator is but would welcome comments from all those who Actual know and/or have had this problem sorted and how..
Many thanks..
Robert
Bob this video might help.
He fixed it in Dec...
What is the part you're advising to glue? I'm presuming you are the author of the video
spock500
Milton Keynes
300TD, 1998
Hello folks, similar problem to OP but probably not the same furry issue or least hope not :)
This is w245 B1700 petrol 2005/6 with no history, basic runaround.
Cylinder four has a miss determined by pulling HT, removed plug - gap looks huge at 1.1mm although OEM plugs are set to 0,9m which I assume is just under 1mm, not 100% sure as separated by a comma, perhaps denoting something different?
If someone could confirm correct electrode gap that would be great, ordered a set of Bosch which should be here tomorrow.
The coil packs which feed 3/4 has two coils, are these independent of each other, i.e could one coil fail (out of the two) leaving the other working fine?
Complete newbie on this stuff as owned a S124 dinosaur for an age :(
Thanks for any pointers.
ajlsl600
france
I live in West London, Uxbridge way. I borrowed a comprehensive LAUNCH code reader. The garage would not commit themselves as to what it was as they were not gonna do the work and not a Mercedes Garage. They can only go on what their code reader indicated.
I have no experience of the STAR diagnostics.. Will it give any more detail than the LUNCH reader. As far as I am aware, both will just read the stored codes? Will it test each component individually?
From what I know, the codes are pointing to the Manifold pressure sensor, or Throttle body. One of them is generating an error.
I have sourced a NEW Patten part, Throttle assembly from Germany. I will be getting hold of the car from my daughter, later this week and will try in sequence to;
- check for vacuum leaks
- fit new air filter,
- clean the throttle unit,
- check the wiring to the Manifold sensor
- Test Manifold sensor and change if necessary
- fit new throttle body assembly.
I suspect something is advancing or retarding the timing and the ECU usually gets inputs from the Throttle Position sensor, MAF, and Manifold sensor and adjusting as necessary?
Yes, the car is a 1.7 Petrol Engine.
Any suggestions welcomed..
Thank You
Bob.
Check out forrera, Mercedes a class specialist.. On Facebook. Based in London. Helpful guy
spock500
Milton Keynes
300TD, 1998
Plugs arrived early, popped those in (real job getting caps off) no change - taped cylinder 4 plug to engine and started, plenty of spark so looks like coil pack okay.
The catalytic convertor is starting to whiff, possibly due to unburnt fuel making its way back ?
If you get a misfire and engine code with Check Engine light then no fuel will be injected into that cylinder to prevent cat damage.
spock500
Milton Keynes
300TD, 1998
Thanks bud, to cut a long story short it looks like the coils are okay, it does however smell quite strongly of petrol fumes which may suggest over fueling.
My attention has turned to the variable intake which has a vac operated switch to one side - mine has a split boot but also noting attached, i wondered if some kind member could check there's to see if anything (or it's blocked off) is connected?
If the intake is closed shut could explain issues as mentioned.
This video at 4.21 describes the part but cannot hear audio to make out what is is?
img_7893-jpg.2641487
img_7895-jpg.2641489
Courtesy of doit vehicles
2020-07-09-5-png.2641490
