Rich R230
- Jul 20, 2020
- R230 SL/2003/500
I dont suppose you know what this rusty pneumatic cylinder does directly behind the light cluster on the auxiliary battery side of my boot do you? It’s a 2003 r230 sl500.If you have Command it's set automatically from the GPS.
Unfortunately the GPS system operates on something called an epoch and when the epoch rolls over the GPS gets the date and time wrong.
Nothing you can do to fix it, however if it's an hour out try selecting another time zone to put the displayed time correct (date will still be miles out).
Thanks in advance
I dont suppose you know what this rusty pneumatic cylinder does directly behind the light cluster on the auxiliary battery side of my boot do you? It’s a 2003 r230 sl500.Close enough for government work...![]()
Are there any pitfalls to replacing one or is it simply pop the clips and replace? Thanks for the info by the wayLooks like the bottom of this one:
That's a boot lift assister for hinging the boot open to stow the roof.
Never replaced one....Are there any pitfalls to replacing one or is it simply pop the clips and replace? Thanks for the info by the way
2004 has the later Comand with the bigger screen. Different software.How come the clock is correct on my 230 Alistair, will it cease to function soon ? It's a 2004 car.
Just curious.
Is it causing a problem?I cannot. Will have a proper look at the weekend.
No it works perfectly, but the cylinder has clearly perished. If it’s simple I’ll do it myself... I don’t sleep if I think something is wrong with herIs it causing a problem?
Rust won't form on the internal bit I wouldn't think. You can check by operating the roof and stopping it as the boot lid gets to the full open position.
Good idea on resting method..No it works perfectly, but the cylinder has clearly perished. If it’s simple I’ll do it myself... I don’t sleep if I think something is wrong with her
A2307500136I don’t suppose you have a part number do you?
The other side is an hydraulic ram operated by the roof pump.If there is one on the other side i would be inclined to replace both at the same time to ensure same/equal operation pressure.
