S203 back end clattering
Lee alexandre
E55 wagon / c220 cdi wagon
Evening!
W203 estate avantgarde, just had shocks replaced by last owner
On uneven roads rear end clatters .... anti roll bar links?
Thanks in advance everyone
mbknighton
C180K
May be wheel carrier bushes, lower arm to subframe bushes...
Or broken spring(s)...
Or worn lower arm bushing, or shocks not fitted correctly or... or... or....
daveenty
The Frozen North :(
2019 AMG S Class Coupe
As stated above, could be a multitude of things.
The only way to check for sure is to get it up in the air and check everything on the back end for any play.
umblecumbuz
Wales and Gozo
Or shocks not fitted properly?
Last thing changed is first thing suspect.
davemercedes
Glos
When my S203 started making odd rattling noises it turned out to be the rear springs breaking up which is apparently not uncommon. March 2015 it cost me £150 + VAT = £180 so not too bad. No problem since (touch wood etc).
But as umble says the last job is always suspect...
Still, at least you can be comfortable that it's unlikey to be a big bucks job.
