Screenwash -- which is best value
rlx
I've tried a few screenwash fluids and most seem to leave smears. Without going overboard cost-wise, which ones give the best results (i.e. not leaving a smear)? Don't need any in-depth analysis, just the names of a couple of brands you are happy with. It'll save an extended test of various brands since a bottle lasts about a year.
R.
whitenemesis
CLS55 AMG '05
I've always used MB own screen wash. Good value, excellent cleaning with no smears. Guaranteed compatibility with nozzles etc..
R
rlx
Ahhh! Nozzles!
Mine keep getting blocked. I assumed it was lime-scale. Maybe I should switch to MB?
Serves me right for using Asda's I suppose...
Yes the MB stuff is very good, but cleaning the screen now and then with T cut can work wonders to remove traffic grease
Triv
Bristol
A brace of s210 1998 e300 turborustbuckets. Toyota HiLux Surf kzn185 3.0L
I agree with the above; MB screenwash works fine for me.
I use toothpaste to clean my screen periodically. It works wonders and removes all diesel film.
huey
Nottinghamshire
W203 cdi 2004 Estate
I always put a tiny drop of fairy liquid in the washer bottle works a treat.
Xtractorfan
S class
Fairy liquid tends to harden up and block the jets..possibly due to its high salt content...
Alex M Grieve
Broom, Warwickshire
I have used a more generous amount that huey and for years now. I have yet to encounter a problem with blocked jets.
The only time I ever experienced blocked washer jets was by overdoing the paste polish that I used in the 1980s. Easily tweaked out with a pin though.
I keep some Mr Muscle in the garage and in bad weather will often wash the windscreen and wipers, the rear screen, mirrors and lights - rather than wash the whole car.
Mr Muscle contains vinegar and that certainly makes for clean glasswork, and prolonged wiper blade life.
Mercedes-2010
Staffordshire GB
Mercedes C350 AMG Sport (2013)
Dump some metalayted spirits in the bottle along with the screen wash and water, cuts the grease magnifico;)
And tooth paste is good for cleaning the screen, and minty fresh too... :lol:
DC x
huey
Nottinghamshire
Well i've been using it for years without any problems, same as Alex tho had blocked jets due to over zealous waxing i just use a bristle from a wire brush to clean/unblock them.
R
rlx
I like the toothpaste idea. And the meths, both worth a try by the sound of things!
syncropaddy
Sunny south east
.... too many cars!
I use the Screen wash that JCB sells and I find it great and if you mix it right it wont freeze. It can also be used as a de icer ......
wireman
lancashire
I use just plain water and find it as good as with additive. Jet blockages are often the result of using a non too clean water bucket to fill the washer bottle.
As some others do I use a decent cleaner when the screen gets the inevitable grease film, Autoglym glass polish seems best to me. Regular cleaning helps keep the grease film down.
Adding 10-20% meths will provide anti freeze properties and little if any grease dispersal, in fact the purple dye in meths will leave a film of oil behind.
Washing up detergent should be avoided like a plague, the very high salt content (used to thicken it) will cause rusting in any gaps it gets into and corrodes the bores of the washer nozzles.
I carry a can of Sif bathroom foam to dispel any greasy film which may build up during a journey (especially winter), it is very effective indeed, supermarket own brands are not as good. I don't know about these detergents rusting abilities, but overzealous use will take the polish (Autoglym super resin) off the paintwork.
An annual new wiper blade is essential in having a streak free windscreen, save the money you'd waste on washer fluid and buy it one for its birthday.
Dosco
W211
Powder variety (Euthymol IIRC) of toothpaste is best - old chauffeurs trick that my dad told me about. He also used a dose of pure paraffin in the water (used after washing off the dirt and grime) to finish off the paintwork then a good leather down - mind you that was on 1930's RR when 'proper' paint was in use;)
If you have a real coating of road film on your screen try 'Bar Keepers Friend' mix to a paste and go over the screen a bit of best quality elbow grease helps do this after washing the car and then rinse off with clean water, finish by polishing the glass with a micro fibre cloth.
mercmeck
FIFE SCOTLAND
SLK 2OO 2012
good old merc screenwash works for me ,clean screen with rain x before washing then add sw for great results . you need good quality wiper blades also
this is my first post .helooooo to all you merc owners
geo p
Alex M Grieve
Broom, Warwickshire
geo p
welcome to the Forum - and full marks for patriotism! ;)
