Seized Pins?
Drivenroundthebenz
Norfolk
1999 Mercedes SLK 230K w209 CLK 220 cdi Sport Coupe
Hi all
Has anyone had seized pins when trying to remove their brake pads. Apparently the pins are steel and the caliper is alloy = corrosion/seizing.
Solution to drill out pins and get a new pin pack from merc! Cars only done 23k on a 09 plate. This only happened on one side, the other was fine.
If anyone has a better idea to remove the pins please let me know!
Cheers
Garthrington
HERTFORDSHIRE
S320 CDI 2002
Had a similar issue with my rear pins. Tried various things to drift them out, but none of them were strong enough and bent.
Then I found an old hardenend steel Allen key of an interference fit, and cut it to about 2". Carefully sprayed the rear of the pin with WD40. I put the allen key on the pin and gave it a hard clump with a hammer. It was enough to get the pin moving, and then drift out completely.
The allen key did still bend, but not as much as some of the other things I tried. Also when replacing them, I used a small amount of copper ease to hopefully stop them getting stuck again.
Gary
D
Drivenroundthebenz
Norfolk
Just came back from garage and the pins are not coming out. They have welded themselves in for want of a better word. They tried the above but the pin just sheared off leaving the rest in place. This is obviously a common problem looking at other threads in the forum. Just my luck!
Frontstep
T210 320cdi
No 1 You need the correct size punch, good weight of hammer and support the caliper by wedging wooden blocks behind.
Proper penetrating oil "WD40 isn't" also helps knocking from both ends helps, rotating the pins with mole grips helps, cleaning the surface corrosion with a wire brush before starting helps, have done a lot in my youthier times and never drilled any pins out even beach running models.
http://www.bennetts.com/p0/premier-mechanics-punches-chisels/80863.htm
For penetrating fluid home made, acetone and auto box fluid.
Or depending on material aluminium cleaner (Acid based one)
Xtractorfan
S class
Suggest you buy this set from made by laser....I think they cost me £12..had a similar problem with my S320cdi ..Rear pads, pins seized, Tried every conceivable pin punch and possible item to remove the pins..no luck...and someone had borrowed the pin punch I need from my other set...So next morning bought these and had the pads fitted in literally minutes..
http://forums.mercedesclub.org.uk/attachment.php?attachmentid=15772&stc=1&d=1309458931
They look very useful, so many try nails and god knows what else and mess up the hole
Cole@MBS
www.mbssouthampton.co.uk
A slight bit of heat and a sharp tap to the housing works, never failed yet to remove one, had to cut them in the centre of the pin then knock them out......
Frontstep
T210 320cdi
Its the old story the right tool for the job a toolbox essential, the punches are so useful for many jobs.
D
Drivenroundthebenz
Norfolk
My local garage got them machine drilled out! Had to get new pins from MB cost £13 What a rip off.
Thanks for all the advice though apparently this happens a lot with this type of brake?
HelpThisDude
Essex
W203 C270CDI, R172 SLK55 AMG
The last time I had this problem, my pin punch tool (Teng tool) just bent, eventually broke.
Is that lazer set any better?
I ended up using a G clamp, along with a 1/4" drive 10mm socket (pin head end), a 1/4" drive 3mm allen bit as a drift (pointy end) and "pressed" the pin out.
Supprised me how difficult it was to remove, as the pin was not fitted that long ago, and it was copper slip coated when fitted.
Will Barber
Cheshire
2012 CL500 (4.7L M278)
Just read this article as I too have seized brake pins in the calipers on my 2005 CL500.
Just to correct something in the previous helpful comments above....
The pad retaining pins are a 2-part component:-
1). The guide pin itself
2). The split/expanding dowel
Getting the pins to turn with mole grips will only confirm the the pin is now free from the outermost part of the caliper. At the innermost part of the caliper, it's NOT the pin that gets siezed in, but the expanding split dowel. This is the part that actually grips on the caliper and keeps the pins where they are.
Sometimes, as I had to do yesterday on my CL, the best way is to grind/cut through the pad retaining pins then knock each of the 2 remenants out with a high quality pin pinch nof the correct diameter.
Using nails and screws to knock them out will only confirm your Neanderthal status and end up wrencking a caliper.! :roll:
Will
e55amggary
Bristol
C220cdi sport edition Auto / A6 2.7tdi Quattro s line Avant
I had this on my Brembo front calipers on my w203. Someone had fitted incorrect pins which had interracted and caused them to swell. Caliper off job and they had to be drilled out.
I bought the correct pin kit costing around £30 from merc
Luckily did,nt have to have new calipers. Silly money
Will Barber
Cheshire
Pad pin kits available from Eurocar Parts for ALL Mercs at around £16 per axle set!
In fact I don't know why so many Merc owners go to their main dealer ??? For my CL500 I've just bought 2 x 330mm cross drilled ventilated Pagid discs and a front set of Pagid pads all for just £109.35 !!!!!!!
Steve@Avantgarde
Bristol/Somerset
All i do is push the pistons back with the pad in situ then get a pair of mole grips on the pin and simply work up and down applying a bit of WD40.
Not hard and always come out that way. On installation, use some graphite grease on the pin.
Will Barber
Cheshire
Believe me, the pins on my calipers were NOT coming out in a month of Sundays.!
I had to cut the pins, remove the pads then tackle the remenants of the pins when they were shorter with a good punch and some localised head.
drdre78
london
mercedes c200 200
hi you know back in day when you used to replace rear brake pads we used to clean up brake pins with wire wheel but know seem that people just don't bother. at main dealers
The main thing needed in removing the pins is a good sized punch, I made my own by grinding down a punch 10" long, and as Steve wd40 and rotating them they do normally come out.
Steve@Avantgarde
Bristol/Somerset
I have had many people say that, but i have never ever had trouble.
drdre78
london
mercedes c200 200
ha I have had this with range rovers and there front brake pins get stuck in
