SL R129 Roll bar will not retract
ADP
Worcestershire
C200K, SL500.
Just sorted one problem to fix the main problem. I have tried most things to retract the roll bar on my 1996 SL but nothing is working at present. Disconnected the battery for 10 mins, held the roll bar switch up for 10 secs, checked all the fuses, and a bit more. I took it in to the garage this morning because I had heard it could be a fault that needed resetting. But the garage told me that were a few faults on the computer that they erased but the fault for the roll bar stayed on? So I have the report code which reads 122 Limit Switch, S83/1 Roll bar stowed. Does any one know what this means and can it be rectified because I can't put my roof up or down, so at present its not locked down on the rear swing arm. The garage suggested it would take a very long time to take the back seats and covering off to expose the ‘switch’, which they weren’t sure, were it was located. But I have half stripped it down, which took 10mins.
:(Any suggestions ADP
Its a 129--- 063-064 ?
stats007
Hampshire
Looking
It takes about 30 minutes to take the panels off - I've done this plenty of times - some videos below. The roll bar has a sensor attached to the hydraulic ram (just used for raising lowering as in emergencies it it spring operated) which sounds like it is at fault being S83/1. It's about £50 from memory.
Send me a Email and I will send it to you
stats007
Hampshire
Looking
It makes no difference whether it was a 6, 8 or 12 cylinder car - all the MY '96 cars came with the final revision of soft-top ECU.
It was the change in 96, that is why I wanted the VIN to know which of the 3 systems it was
stats007
Hampshire
Looking
Well the change happened in late '95 for the '96 MY so being a 1996 car I took it as read though you can never be sure I suppose Malcolm!
S83/1 is part A1298207910 - it's on the nearside ram.
I have copied off the work sheet for him, its easier
A
ADP
Worcestershire
C200K, SL500.
Thanks for the link, but is there anything that will show me where the switch is located on the ram and is the number you have listed the part number required?
Thanks for your help
ADP
A
ADP
Worcestershire
C200K, SL500.
Sorry didn't realise you needed the full Vin. I can't get it until the morning as not at home until then. I will e-mail it then.
Cheers
ADP
stats007
Hampshire
Looking
You'll see it - it's a rather large sensor sticking out of the side of the ram. That's the replacement part number - though you should test the old one first as a matter of course.
A
ADP
Worcestershire
C200K, SL500.
Will do, thanks again
ADP
stats007
Hampshire
Looking
I've uploaded it Malcolm in case anyone else wants to refer to it. Basically you just unscrew it :D!
A
ADP
Worcestershire
C200K, SL500.
Thanks both of you I will have a go at it tomorrow and let you know how I get on.
Cheers
ADP
A
ADP
Worcestershire
C200K, SL500.
  • #19
I have taken the switch off and its showing continuity! So has anyone got any other ideas.
Confused
ADP
stats007
Hampshire
Looking
Until the fault code has been reset you're stuck. If the sensor is just on/off then either the wiring is dodgy or the ECU has a problem if it's generating this fault code consistently.
