SL / R129 Window adjustment to reduce wind noise
gladholm
Top of Cambs
Black SL320 2000 R129
I am attempting to reduce the whoosh of wind noise from my passenger window at speeds above 50+. (SL320 2000 - 54k) The noise is damped by 4 layers of gaffer tape stuck across the top leading edge of the glass. Not cool! So I figure I have to adjust the glass up by approx 2 - 3 mm. The glass does raise and fall the 12-15mm upon opening and closing the door, but just not up enough!
What's the process... loosen 3 nuts at the pink arrows, and lever the glass up and re-tighten, or is there something else I should know? Is there some adjustment on 1 and 2 or near my marked red blobs?
Thanks for your help...
with an Email address I can send you the instructions
gladholm
gladholm
Top of Cambs
thanks Malcolm
please acknowledge here and I'll remove later
Cheers
Richard
Its sent, go back and edit out you Email address
gladholm
gladholm
Top of Cambs
Adjusting the door to close properly
Thanks Malcolm for the extensive notes. I see that I must also adjust the door before the window. Have you any notes per chance on this eg 72-050 ? Thanks
Richard
I will check this evening
gladholm
gladholm
Top of Cambs
door adjusting R129
Thanks Malcolm
Richard
I have sent it
Dglm
S.Yorkshire
SL320 2000 Metallic Blue.
Malcolm,
I would also find the information on the adjustment of windows/doors on a SL320 (R129) useful. Would you willing to forward this information to me as well? I have forwarded my email address to you directly.
Many Thanks.
David
I have sent them on to you and welcome to the forum
discoking
South Shields
www.facebook.com
1985 500SEL
fabulous video,thanks for posting it.
I need to do this on my 129 to reduce wind noise but where do I get those spacer gadgets and the door wedge thingy from?
That is the joke, you cant get hold of them so it rather makes it pointless other that where the adjustment points are, but my papers show those
discoking
South Shields
www.facebook.com
1985 500SEL
Bah,thats a bit of a bummer then.
hate to ask as you get lots of requests but is there anychance you could mail me the papers please Malcolm?
jusxxxxxxxxxxxxx.co.uk
I have sent them,,you can go back to your post and remove the Email address
Dglm
S.Yorkshire
Thanks Malcolm for the information, which I have received.
stoneage
east midlands leicester
alfa, and merc 500sl 91 m119
sl window and door adjustment
HI JUST READ YOUR THREAD ,WOULD IT BE POSSIBLE FOR YOU TO SEND ME THAT INFORMATION ON THE ADJUSTMENT OFF THE WINDOW AND DOOR ON THE SL, HAVE JUST REPLACE MY GLASS ON THE N/S AND CANT GET IT RIGHT THANKS :confused:
Yes I can send it to you :D:D
You can remove the address as sent
www.ckinsurance.co.uk
