SL350 central locking problem
Got every thing back in ok ,started engine and SRS light on,does it need re setting,what needs to be done to rectify
With the SRS lamp it needs STAR to turn that off, was a fuse pulled for the SRS
STEc74
STEc74
St Helens,Merseyside
My car SL 350 05,sons car CLK320,other cars BMW 318IS ,95, 1964 Chev Corvair Monza restoring.
  • #62
No didn`t pull any fuses just replaced blown fuse for pump,didn`t know i had to pull fuse for SRS,is car safe to drive,
Yes the car is safe to drive,,it may go out, try it and see
STEc74
STEc74
  • #64
Took car out for drive but SRS light staying on together with 1 malfunction,does this meen a trip to star or leave it for a while to see if it goes out after a few more miles.
the only connections pulled were those for the pump so why would it effect the srs system.
I wish that I had the answer to this, but I do not,,it could be a seat connector or belt fault, it will have to go on STAR, there is no other way.
The PSE pump has nothing at all to do with the SRS system
STEc74
STEc74
  • #66
Will take it early next week,, these systems seem very temprimental, like you say may be a seat belt fault, hope nothing to serious though.
Thanks.....Steve.
Most SRS system faults are the connectors, the trouble is its a safety system, and the only part of the car that needs STAR to check it and turn it off, there may not be any fault and rare to have this fault on a 230
PetercSL
London
SL 350 2003
A good and helpful thread. The central locking fuse on my SL 350 is blown. I removed the pump and checked the foam but it is all dry. Very cold today but I don't think the problem is water ingress. Do you know of any other reason why this fuse might blow
Thank you
If all dry and clean in the cold weather the turbine vanes can break up, the center hole in the carbon rotor is really too tight and it breaks up.
The pumps are dead easy to take apart, the case just splits, you can unsolder the motor and try it across the battery, when the rotor breaks up the motor will not turn. The repair kits are on Ebay.
Welcome to the forum, I forgot :D:D
STEc74
STEc74
  • #72
Hi Malcolm, Just to put you in the picture on the SRS fault which accured 2013
I forgot to reply with results at the time,itook the car for star diagnosis and found that the seat belt retactor was faulty,so had it changed,£200+ labour
all has been well since:D
Regards Steve.
Regards Steve.
Thanks for that its always nice to no the end result. :D:D
spokido
Ixworth
SL/2005/3.7
Im having a problem with my boot lock every think else works but I can't open the boot by key fob or with in side .
had diagnostic done and told boot lock to be changed on changing they found another two faults and the boot was going to ground.????
no wet in or around PSE Pump was also told they could open close the boot from the STAR System lap top but as soon as they tried to open manually thats when it went to ground
can you gurus advise please
thanks
wade
Does the metal key turn in the lock, it should be spring biased in one direction, when the key is held in this position the handle should engage.
spokido
Ixworth
SL/2005/3.7
Hi
I can use the key turn to the left and the handle engages and I can open the boot ,Im a fellow Dorset boy from Weymouth lol
So it doesn't work when I use key fob to unlock the car , I have to use the key to gain entry which defeats the objective of the system
Thank you, The problem could be a broken wire in the hinge area, or the lock in the lid has failed.
David Arnott
Aberdeen
SL500 2009
thanks
wade
What do they mean by "the boot was going to ground" ?
To find the problem please measure the voltage on Pin 1 of the small (6 pin) connector on the PSE central locking pump.
This pin should be at (approx.) 12 Volts and go to (approx.) zero when you operate the opening handle.
If you can find this out we can move forward.
Attached is the schematic / wiring diagram, if it will help
Regards
  • Wiring diagram of pneumatic controller unit (PSE).pdf
spokido
Ixworth
SL/2005/3.7
The mercedes tech said when they put the new lock in it would work ok off the Star laptop but when opening by hand the circuit went to ground IE I presumed earthed out so they refitted the old one.
so as previous have will not unlock when using key fob or internal door switch
Hi Dave will look at that in the next few days and feed back thanks for your support and advise
Very hard to follow "Gone to ground" one connection is ground, there are 2 ways to do wiring, leave the item live and use the ground connection for switching.
