SL55 starting problem
pk311ymb
Hollingbourne, Kent
2003 SL55 AMG
Hi all, my SL won't start after being left in the Sun. I suspect fuel vaporisation but I suppose it could be a fuel pump on its way out? It is accompanied by the Emissions warning lamp coming on intermittently. Any ideas?
BachelorDays
Wandsworth, London
2000 w210 E240 91k (Nov13)
You've got to give a bit more info. Does it crank, etc. How long has it been parked in the Sun?
P
pk311ymb
Hollingbourne, Kent
2003 SL55 AMG
Hi - yes it cranks very well. It's not a battery problem. It was in the Sun for less than an hour. After a few tries it starts and runs normally.
Had you driven the car shortly before, and parked it up?
BachelorDays
Wandsworth, London
Warm engine that cranks but refuses to start until given a rest for a bit is almost always a crankshaft position sensor.
If it happens first thing in the morning too, or after the car has been sitting there for 3-4 hours, then I'd think fuel supply.
Was going to mention cps, they also tend to show failures on very hot days when stuck in traffic.
P
pk311ymb
Hollingbourne, Kent
2003 SL55 AMG
Yes. I should have said it cranks very briskly once you engage the starter (key or keyless) and after 5 secs or more it stops cranking having failed to start.
P
pk311ymb
Hollingbourne, Kent
2003 SL55 AMG
Crankshaft position sensor sounds plausible - would that illuminate the Emissions light?
Doesnt always light the check engine light, but it will log a fault code. Its approximately 50 pound part, from Mercedes, 1-2 hours labour to change.
BachelorDays
Wandsworth, London
You mean the Engine Management Light. CPS often doesn't throw its code. However, on my car it would - and the EML would come on too.
You could get hold of a cheap scanner (£10+) and get the codes. If the EML comes on, you'll have a code in there.
P
pk311ymb
Hollingbourne, Kent
2003 SL55 AMG
OK chaps - next question - can I fix it (quite handy) or is it a garage job?
Its not difficult to actually replace, but access can be hard. Its located at 2 o clock in the bell housing at the back of the engine, and they can get stuck in place. Its held in with a Torq bolt
