SLK / R170 Water Leak
I noticed the other week the drain under the petrol flap wasn't draining - tried bits of this & that - eventually solved by using a syringe (as in medical - you should be able to get from a chemist so long as it doesn't have a needle attached!).
It didn't work when I tried it "dry" - the air just compressed, but I filled it with water & gave a it really good blast & all the filthy water suddenly appeared on the ground - works fine now.
How can you allow filthy water in your wonderful motor car :confused:
Don Parker
Rain, rain go away.
Dear all,
Have the same problem as Moosehead on my Mercedes-Benz R170 3.2 L V6 (Brabus)! Malcolm, I've read your posts and checked your link to the drain issue (pretty sure thats the problem). Could I please have the paper that you refer to? Fairly sure that my email is included in posts, if not please let me know and I'll post, then remove after receipt.
I have posted this question in another forum, my apologies, new to the forum and made a school boy error.
Hope you can help?
Best,
Don
Dear all,
Hope you can help?
Best,
Don
No trouble Don,,I cannot access your address can you pop it up for a few mins
racall
london
c class and slk
I wouldnt mind the info just it case
Cheers
Ph§§§§§§§§§§§§§§§§§§§§§§§§§§§§§uk
Cheers
You have it sir :D:D
2 papers sent you can take down the address in edit now
Don Parker
Hi all,
Still have water leaking into the SLK after checking drains. Cleaned all the drains. VAXed up the excess water. Just took it through a carwash (I know, I know). Appears I have a small puddle of water that keeps occurring BEHIND the passenger seat (so not emanating from the footwell as I first thought). The water is clean and appears limitless. Can also hear what appears to be water sloshing around in the sill. Stumped.
Any ideas?
SLK R170 V6 Brabus (or "boat" as I am currently calling it)
This must be the roof seams,,did I send that paper Don
Don Parker
Hi Malcolm,
Yes you did (Thanks). I'll have another look and report back over the week.
Don
One never knows if the roof joints have been adjusted too tight, leaving no way to close the joints further,,it may be necessary to replace one of the roof seals in order to fix the problem.
It should be possible to detect what seal by just running a hose over the front or rear seal in turns, by putting an old blanket over the center of the roof, you can isolate the front and rear sections
chris_uk82
West Midlands
2011 C350 BlueEfficiency AMG 125 Edition
Hi Malcolm, Could you also let me have a copy of your paper on checking/cleaning the air-con for blocked drainage pipes? I have a 2002 SLK 320 and I noticed during this last weeks cold spell that the passenger footwell had a puddle full of frozen water :( This is the second time this has happened and the water isn't coming from outside the car. I've left the EC button on, which apparently disables the air con and there have been no further leaks.
Any help would be very much appreciated
Chris.
cunitt@gmail.com
Chris.
Hello and welcome to the forum,,I have sent you the paper from the air intake,, now right under the car over the gear box you have the main heater box drain, and that will need to been cleaned out its 320 in the picture
chris_uk82
West Midlands
cheers for that I'll see what i can find tomorrow don't know whether I will be able to find the assy above the gear box as i don't have the appropriate tools for jacking the car up. thanks very much for your help though
Its worth asking when the car is in for the MOT if they or you can do this
coventryslk
Coventry
W204 CDI Sport
Should i just jack up the car or remove wipers etc to gain access?
chrisbutty
Cambridgeshire
SLK 2.3 2001 WDB170
A/C causing damp? Same here.
I've isolated the cause of infeasible amounts of condensation I get on windscreen and rear screen by stopping using the A/C for a few weeks.
Could you please sent this popular paper on unblocking AC drains. I've looked all over the drawings on www.detali.ru and eventually found something but WHERE IS IT ON THE CAR!
Secondly, as I just googled my chassis number, and found it's for sale in Japan??!
http://exchange.goo-net.com/usedcars/spread/700040203720101112002.html
How come, I thought these numbers were unique??
The heater box drain comes out I believe just between the wheel arch liners and the bulkhead. there are no papers for drains for the 170. pop your VIN number into here
http://www.neoriginal.ru/cat/mb/ and get the chassis card.
there is only one car with this allocated VIN number
chrisbutty
Cambridgeshire
SLK 2.3 2001 WDB170
Thanks for that. I had foreshortened the VIN, the full one is WDB1704492F225142 so I stuck that in the link you provided and it came back with a bag of symbols which translated as "Error! This VIN- number is not found in [BD]! " I guess that's DB for database to us.
Now I'm confused.
Wozza785
Sussex
R170/2001/230 kompressor
Help water leaking!!
Hi Guys im new to the forum and already i have seem to have a problem like some others. I have a 2001 slk 230k and with the bad weather we've had my passenger footwell is swimming with water. Not good when the wife is getting wet feet!(Lol) From looking on here i see the drains get blocked can anyone send me the paper i need to be able to clear it? Many Thanks
