Smelly Air Con
dazzawm
CLC200 2009
Sorry if I have posted in wrong place. I have a CLC and my air con smells when on. I have let off one of those air con 'bombs' but hasn't made much difference. I don't think it needs re-gassing as the air comes out fairly cold, any suggestions please?
mioba
Nottingham and Köln
your pollen/ac filters may well be old and holding something leading to musky smell.
When were they last changed.
Get original or the top end MANN ones.
jays705
Harrow
E350 CGI and Cl63 AMG
I've used this a few times sprayed into the air intake ideally take out the pollen filter, aircon on in recirculating mode and spay for a few seconds
usernamed
C-Class W204 (2012) C 220 CDI
Personally I’d find an a/c specialist and let them work at it. I used Red Dragon Air Con in South Wales when I had a similar issue, can’t remember the total cost, but I’m confident it was a lot cheaper and more effective than taking it to an MB dealer would have been. There’ll be a company somewhere near you that does the same thing. I think they replaced a filter, did a re-gas, and pumped something through the system to clear the pipes.
Have had no problems since. Think the total came to about £130.
rifiki
Worksop
CLK W209 W121190B
When fixed use it all the time, no fogging in winter.
2 cars in 22 years have done nothing to ACs.
Doug1234
Bedfordshire uk
1997 w210 e300td
This …
joderest
ML270 2003
if the pollen filter is blocked with gunge, no amount of smelly things will work.
Change the filter, its a cheap item, then look for something else
JBell
Torquey
C350 CDi Estate (GAD Edition)
Have you checked under the passenger front carpet for moisture? Could be a wet filter caused by blocked drains
Replace the filter with a MANN Frescious Filter
